I am trying to plug an external monitor to my laptop with a HDMI cable in order to have a dual screen.
When I do so, nothing happens, the external screen is not recognized at all. I think that's because the driver of my laptop's video card is not properly installed/enabled.
To install the drivers, all I did was
sudo add-apt-repository ppa:graphics-drivers/ppa
and then used 'additional drivers' GUI to setup nvidia-driver-430 on my system.
I rebooted my machine and nothing changed, the external monitor is still not recognized...
When I try to launch nvidia-settings, I get this error :
ERROR: Unable to load info from any available system
(nvidia-settings:3585): GLib-GObject-CRITICAL **: 17:36:06.267: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 17:36:06.271: PRIME: No offloading required. Abort
** Message: 17:36:06.271: PRIME: is it supported? no
Here's the output of nvidia-smi :
| NVIDIA-SMI 430.40 Driver Version: 430.40 CUDA Version: 10.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce GTX 1650 Off | 00000000:01:00.0 Off | N/A |
| N/A 39C P8 1W / N/A | 0MiB / 3911MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
I am running Xubuntu 19.04 with 5.0.0-20-generic kernel and I've disabled 'Secure boot' in the BIOS.
lsmod | grep -i nvidia :
nvidia_uvm 847872 0
nvidia_drm 45056 0
nvidia_modeset 1114112 1 nvidia_drm
nvidia 19025920 12 nvidia_uvm,nvidia_modeset
drm_kms_helper 180224 2 amdgpu,nvidia_drm
drm 475136 9 gpu_sched,drm_kms_helper,amdgpu,nvidia_drm,ttm
ipmi_msghandler 102400 2 ipmi_devintf,nvidia
lspci | grep -i --color 'vga\|3d\|2d' :
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f91 (rev a1)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso (rev c2)
sudo lspci -v -s 01:00.0 :
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f91 (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Device 109f
Flags: bus master, fast devsel, latency 0, IRQ 68
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at f000 [size=128]
[virtual] Expansion ROM at f7000000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Capabilities: [bb0] #15
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
This is really annoying... Anyone could help me out on this ? Thanks in advance
