11
I am going to reinstall Windows on my computer so that I can flash the UEFI/ BIOS (the computer manufacturer only supplies a .exe file). I would like to efficiently reinstall Ubuntu after that. Can you explain a time efficient way to do that?
Edit: Really, I am looking for the safest way to do this with a reasonable degree of efficiency.
The most efficient way is to find a Live Windows image and boot from it.
You will be able to flash BIOS from it.
But beware that in some cases it is not a good idea to flash a new BIOS. About a week ago I flashed a new BIOS to an Asus laptop using a BIOS utility (built in into BIOS called EasyFlash).
After that I lost touchpad in Ubuntu and had other problems. I couldn't downgrade BIOS using the same utility because it didn't allow to flash older BIOS.
So I had to use a Live Windows image where I successfuly downgraded BIOS using /nodate switch.
So if you don't have a very strong reason, and everything works fine, don't upgrade BIOS. Ubuntu will take care of CPU microcode.
Pilot6
  • 92,041
13
Disconnect your Ubuntu system drive, connect an old spare or used drive, install Windows on it, and do the BIOS update (if, as Pilot6 explained above, if you absolutely, positively, have to update the BIOS). Then, disconnect the old drive, put your Ubuntu OS drive back on, and you're ready to know, secure in the knowledge that Windows did not corrupt Linux.
K7AAY
  • 17,705
The most time efficient method of putting an existing Ubuntu installation back on your system is to boot from a thumb drive, do a complete image backup of the entire drive to another (large enough) storage device, then restore that image backup after you're done with Windows.
I'll link an article on how to do this (be careful; you can erase everything as easily as backing it up), but dd is the core command for these operations.
Zeiss Ikon
  • 5,248
If your .exe flasher tool does not need installation, then you may be able to do this from the Windows installer disc.
Download a Windows 10 installer iso image from Microsoft of the appropriate bitness (32-bit or 64-bit). If you visit the site from Windows, then Microsoft wants you to download their "Media creation tool", which can either download an iso or create a bootable USB drive. I believe the site simply offers the iso file if you visit from Linux, but I haven't tried. This is a free download, and you don't need a license since you won't be installing.
Boot the computer with the installer disc. Progress through the installer until you come to the "Install Now" screen, don't click that button, and press Shift + F10 to open a Command Prompt window. From there you can do many things, for example: Plug in a USB drive with your flasher .exe on it, navigate there (you may have to try a few drive letters to find the correct one), and execute it.
