OS, apps and hardware info
Linux local 5.0.0-23-lowlatency #24-Ubuntu SMP PREEMPT Mon Jul 29 16:17:02 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
jackdmp version 1.9.12 tmpdir /dev/shm protocol 8
Bitwig-studio version 3.0.1
USB2 Audio interface Tascam US16x02
Question
Is possible run audio application with max priority for this application? For best performance and lowest latency without cruckling/buffer problem for audio application.
Situation
I reinstalled Ubuntu studio 19.04, update, upgrade, install DAW Bitwig studio 3.0.1, then install indicator-cpufreq (for changing my cpu to best performance).
Then I ran jackd in this configuration.
/usr/bin/jackd -dalsa -dhw:US16x08 -r44000 -p128 -n2
I select in indicator-cpufreq applet Performance (for best performance), then checked via lscpu it is working.
Model name: Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz
CPU MHz: 3455.159
CPU max MHz: 3500,0000
CPU min MHz: 400,0000
NUMA node0 CPU(s): 0-3
Then I ran Bitwig studio. I tried do load some my older project.
Issue
When play the music in DAW, there are some crackling during the playing, and when I do something in DAW during playing (for example zooming or moving only), crackling is even worst.
Jackd log shows me many xruns.
I swear I had same configuration before reinstall OS and it was OK for this configuration, no crackling at all during playing even when working in DAW during playing or recording.
I tried install older versions of Ubuntu studio, no effect, crackling still present, same.
Why is now crackling due playing in DAW? Applet indicator-cpufreq changed to best performance, but seems not for DAW, no effect for CPU load in DAW when I selecting between Performance and Powersave in indicator-cpufreq, but lscpu shows me different CPU MHz.
What is the magic? Before I reinstalled OS, everything works fine. I found something about nice utility. Is it what I need to setup?
Thank you very much for any information.
