I know there are plenty of threads on this topic, but apparently you need 50 rep to comment. I have, however, tried all the things in those threads.
Running Ubuntu 18.04 with nvidia-driver-430*. The asterisk is that when I tried downgrading to nvidia-driver-390 my additional drivers tab now shows "continue using manually installed driver" and the options for 390 and nouveau are greyed out. So I'm probably using 390?
Anyway, the problem is the same regardless if I use nouveau or any of the nvidia drivers. The second monitor is just not detected. It was working but when I tried to fix a completely different problem, tearing in videos, it stopped detecting it after I set my prime profile to intel. Switching back to nvidia didn't fix it.
I'm currently running: i7 8750H, RTX 2070, 1080p 144hz built in display, some benq 1440p 60hz external connected via hdmi
When I reboot to Windows, the monitor works fine. So it's not a problem with the wire nor the monitor.
Update:
output of nvidia-smi :
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver.
Make sure that the latest NVIDIA driver is installed and running.
Update:
Switched back to 430, output of nvidia-smi :
| NVIDIA-SMI 430.40 Driver Version: 430.40 CUDA Version: 10.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce RTX 2070 Off | 00000000:01:00.0 Off | N/A |
| N/A 49C P0 34W / N/A | 191MiB / 7982MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1884 G /usr/lib/xorg/Xorg 106MiB |
| 0 2207 G /usr/bin/gnome-shell 67MiB |
Update:
Output for xrandr :
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 381mm x 214mm
1920x1080 144.00*+ 60.01 60.02 59.97 59.96 59.93
1680x1050 84.94 74.89 69.88 59.95 59.88
1600x1024 60.17
1400x1050 85.00 74.76 70.00 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 100.00 85.06 85.00 75.00 75.00 70.00 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 85.02 74.96 69.88 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 85.08 74.76 70.06 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
720x450 59.89
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98 85.08
576x432 100.11 85.15 85.09 75.00 75.00 70.00 60.06
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
Output from dmesg | grep -i nvidia :
[ 2.731757] nvidia: loading out-of-tree module taints kernel.
[ 2.731764] nvidia: module license 'NVIDIA' taints kernel.
[ 2.740486] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.749928] nvidia-nvlink: Nvlink Core is being initialized, major device number 239
[ 2.751126] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.751247] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 2.793153] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 430.40 Sun Jul 21 04:53:48 CDT 2019
[ 2.807484] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 430.40 Sun Jul 21 04:57:42 CDT 2019
[ 2.809576] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.472496] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input25
[ 3.472598] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input26
[ 3.724291] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 3.734373] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 237
Output for grep -i nvidia /var/log/Xorg.0.log :
[ 15.088] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia-430/xorg,/usr/lib/xorg/modules"
[ 15.088] (**) OutputClass "Nvidia Prime" ModulePath extended to "/x86_64-linux-gnu/nvidia/xorg,/usr/lib/x86_64-linux-gnu/nvidia-430/xorg,/usr/lib/xorg/modules"
[ 15.088] (**) OutputClass "Nvidia Prime" setting /dev/dri/card1 as PrimaryGPU
[ 15.092] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[ 15.092] loading driver: nvidia
[ 15.092] (II) Applying OutputClass "Nvidia Prime" to /dev/dri/card1
[ 15.092] (==) Matched nvidia as autoconfigured driver 0
[ 15.092] (==) Matched nvidia as autoconfigured driver 1
[ 15.092] (II) LoadModule: "nvidia"
[ 15.092] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia-430/xorg/nvidia_drv.so
[ 15.095] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 15.096] (II) NVIDIA dlloader X Driver 430.40 Sun Jul 21 05:01:54 CDT 2019
[ 15.096] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 15.096] (II) NOUVEAU driver for NVIDIA chipset families :
[ 15.099] (II) NVIDIA(0): Creating default Display subsection in Screen section
[ 15.099] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 15.099] (==) NVIDIA(0): RGB weight 888
[ 15.099] (==) NVIDIA(0): Default visual is TrueColor
[ 15.099] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 15.099] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 15.099] (II) Applying OutputClass "Nvidia Prime" options to /dev/dri/card1
[ 15.099] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 15.099] (**) NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
[ 15.099] (**) NVIDIA(0): Enabling 2D acceleration
[ 15.099] (II) Loading sub module "glxserver_nvidia"
[ 15.099] (II) LoadModule: "glxserver_nvidia"
[ 15.099] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia-430/xorg/libglxserver_nvidia.so
[ 15.134] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 15.134] (II) NVIDIA GLX Module 430.40 Sun Jul 21 05:00:26 CDT 2019
[ 15.165] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 15.165] (--) NVIDIA(0): DFP-0 (boot)
[ 15.165] (--) NVIDIA(0): DFP-1
[ 15.165] (--) NVIDIA(0): DFP-2
[ 15.167] (II) NVIDIA(0): NVIDIA GPU GeForce RTX 2070 (TU106-A) at PCI:1:0:0 (GPU-0)
[ 15.167] (--) NVIDIA(0): Memory: 8388608 kBytes
[ 15.168] (--) NVIDIA(0): VideoBIOS: 90.06.2d.00.55
[ 15.168] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 15.198] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 15.198] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 15.198] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 15.198] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 15.198] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 15.198] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 15.198] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 15.198] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 15.198] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 15.234] (==) NVIDIA(0):
[ 15.234] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 15.234] (==) NVIDIA(0): will be used as the requested mode.
[ 15.235] (II) NVIDIA(0): Validated MetaModes:
[ 15.235] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 15.235] (II) NVIDIA(0): Virtual screen size determined to be 2560 x 1440
[ 15.278] (--) NVIDIA(0): DPI set to (91, 91); computed from "UseEdidDpi" X config
[ 15.278] (--) NVIDIA(0): option
[ 15.590] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 15.590] (II) NVIDIA: access.
[ 15.614] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 15.699] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 15.699] (==) NVIDIA(0): Backing store enabled
[ 15.699] (==) NVIDIA(0): Silken mouse enabled
[ 15.699] (==) NVIDIA(0): DPMS enabled
[ 15.699] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[ 15.699] (II) NVIDIA(0): [DRI2] Setup complete
[ 15.699] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 16.213] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event19)
[ 16.213] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event20)
[ 16.270] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 16.270] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 16.270] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 16.270] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 16.270] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 16.270] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 16.270] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 16.270] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 16.270] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 16.335] (--) NVIDIA(GPU-0): DFP-0: connected
[ 16.335] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 16.335] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 16.335] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 16.335] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 16.335] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 16.335] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 16.335] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 16.335] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 16.340] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 16.340] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 16.340] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 16.340] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 16.340] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 16.340] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 16.340] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 16.340] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 16.340] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 17.088] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 17.088] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 17.088] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 17.088] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 17.088] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 17.088] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 17.088] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 17.088] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 17.088] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 17.119] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 17.119] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 17.119] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 17.150] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 17.150] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 17.150] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 17.182] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 17.182] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 17.182] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 17.182] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 17.182] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 17.182] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 17.182] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 17.182] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 17.182] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 17.446] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 17.446] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 17.446] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 17.446] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 17.446] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 17.446] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 17.447] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 17.447] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 17.447] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 17.477] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 17.477] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 17.477] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 17.477] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 17.477] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 17.477] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 17.477] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 17.477] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 17.477] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 19.206] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 19.206] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 19.206] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 19.206] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 19.206] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 19.206] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 19.206] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 19.206] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 19.206] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 19.236] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 19.236] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 19.236] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 19.236] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 19.236] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 19.236] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 19.236] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 19.236] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 19.236] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 20.575] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @2560x1440 +1920+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 23.616] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 23.616] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 23.616] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 23.616] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 23.616] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 23.616] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 23.616] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 23.616] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 23.616] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 23.646] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): connected
[ 23.646] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): Internal TMDS
[ 23.646] (--) NVIDIA(GPU-0): BenQ BL3200 (DFP-0): 600.0 MHz maximum pixel clock
[ 23.646] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 23.646] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 23.646] (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
[ 23.646] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 23.646] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 23.646] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 608.305] (II) NVIDIA(GPU-0): Deleting GPU-0
Update:
The line you specify to edit doesn't mention nouveau. This is what my line currently is: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Update:
Out put from grep -i nvidia /var/log/Xorg.0.log after editing grub line to GRUB_CMDLINE_LINUX_DEFAULT nouveau.modset=0 : https://paste.ofcode.org/GEJ9KRDsQwKcXhJSBU66Ma (ran out of characters, had to use external site)
Update:
Output from xrandr : https://paste.ofcode.org/hgadLwahXYMEdC3hkp7yTV
Update:
Output from prime-select query is nvidia
Output from ubuntu-drivers list is nvidia-driver-430
Output from `ubuntu-drivers devices is:
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00001F10sv00001462sd00001272bc03sc00i00
vendor : NVIDIA Corporation
driver : nvidia-driver-430 - third-party free recommended
driver : xserver-xorg-video-nouveau - distro free builtin
Output for lsmod | grep nvidia is:
nvidia_uvm 815104 0
nvidia_drm 45056 6
nvidia_modeset 1114112 1 nvidia_drm
nvidia 19025920 278 nvidia_uvm,nvidia_modeset
drm_kms_helper 172032 2 nvidia_drm,i915
drm 401408 19 drm_kms_helper,nvidia_drm,i915
ipmi_msghandler 53248 2 ipmi_devintf,nvidia
Output from lspci -nn |grep -E "VGA|Display|3D" is:
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:3e9b]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:1f10] (rev a1)
