Well, I think I found the answer. First, you should take ownership of /usr/share/backgrounds and /usr/share/backgrounds/contest/precise.xml using the chown command. Then you can copy your favorite image(s) to /usr/share/backgrounds. Then you can modify precise.xml to do your desired job.
Open precise.xml in a text editor. Suppose the image you want to add is named ABSTRACT-AnotherBlue_1024x768.png. Then you should copy one part of the body program and modify it like:
<static><duration>1795.0</duration>
<file>/usr/share/backgrounds/ABSTRACT-AnotherBlue_1024x768.png</file></static
<transition><duration>5.0</duration>
<from>/usr/share/backgrounds/Twilight_Frost_by_Phil_Jackson.jpg</from>
<to>/usr/share/backgrounds/Twilight_Frost_by_Phil_Jackson.jpg</to></transition>
Note that the next image name is Twilight_Frost_by_Phil_Jackson.jpg, so you should copy this piece just before:
<file>/usr/share/backgrounds/Twilight_Frost_by_Phil_Jackson.jpg</file></static>
<to>/usr/share/backgrounds/Precise_Pangolin_by_Vlad_Gerasimov.jpg</to></transition>
Now save and exit. Then restart your computer. You're done!
