My problem comes with two symptoms: 1st in booting I’m able to log in, but the system then freezes and I cannot input anything.
Second, and more common is the issue that displays after the computer auto opens the GNU GRUB and I select Ubuntu:
nouveau 0000:02:00.0: bus: MMIO read of 00000000 FAULT at 022554 [IBUS] nouveau 0000:02:00.0: bus: MMIO read of 00000000 FAULT at 10ac08 [IBUS] /dev/sda1: recovering journal /dev/sda1: Clearing orphaned inode 524312 (uid=121, gid=125, mode=0100600, size=51746) /dev/sda1: clean, 135586/61054976 files, 5))8159/244190208
Sometimes the login menu opens after this but again, my system freezes.
As further context while installing I had to restart a bunch of times because the installer would freeze. Maybe 10x before it worked, but now I can’t reboot properly.
From what I’ve found online the issue is probably related to the nVidia graphics card on the Inspiron 7559. I’ve tried some of the solutions through the GRUB but haven’s had success. I’m trying to reinstall now with a USB, but it’s freezing on install. Any advice would be great, hopefully trying to re-install isn’t going to cause me more problems.
