I have three hard drives installed on my machine, they are arranged chronologically in boot priority in my BIOS:
  • 64 GB SSD Windows Seven | NFTS
  • 120 GB HDD Ubuntu 11.10 | DAT4
  • 500 GB HDD Storage For Both | NFTS
What I am looking to do is make it so that GRUB will boot Windows 7 as my primary OS and always offer the option of Ubuntu. Currently, GRUB is on the MBR of the 120 GB HDD (Second in boot priority); and always boots Ubuntu by default. The only method I have found to getting Windows 7 to boot automatically is by physically detaching the HDD. I am running a custom built machine, 64-bit architecture LGA 1155 Mother Board; let me know if you need any other system information.
I am hoping to boot GRUB and have Windows 7 as the default option.
RSX-1327
  • 195
From Ubuntu run cat /boot/grub/grub.cfg | grep menuentry. Starting from zero, count down to the Windows entry, so if it's the eighth entry, you count to 7.
Then edit grub:
sudoedit /etc/default/grub
Change the GRUB_DEFAULT=0 line to GRUB_DEFAULT=X where X is the number you counted to. ControlX, then Y to save and exit. Then run:
sudo update-grub
And when you reboot that entry should be selected.
Note: This method didn't used to be recommended because the list would grow as more kernels were added in updates but now Ubuntu has a more fixed kernel list. If you manually add extra entries in the future you may find that you need to change which is set as the default.
Oli
  • 299,380
