I'm trying to run games through Lutris and followed their wiki on installing wine-staging.
When running:
$ sudo apt install --install-recommends winehq-staging
I get the error they predict, but then when running:
$ sudo apt install --install-recommends winehq-staging wine-staging wine-staging-i386
I still have the unmet dependencies error (output below).
Could anyone direct me to a solution?
Reading package lists... Done
Building dependency tree
wine-staging : Depends: wine-staging-amd64 (= 4.13~bionic) but it is not going to be installed
wine-staging-i386:i386 : Depends: libfaudio0:i386 but it is not installable
Recommends: libcairo2:i386 but it is not going to be installed
Recommends: libcapi20-3:i386 but it is not going to be installed
Recommends: libcups2:i386 but it is not going to be installed
Recommends: libglu1-mesa:i386 but it is not going to be installed or
libglu1:i386
Recommends: libgsm1:i386 but it is not going to be installed
Recommends: libgssapi-krb5-2:i386 but it is not going to be installed
Recommends: libgtk-3-0:i386 but it is not going to be installed
Recommends: libkrb5-3:i386 but it is not going to be installed
Recommends: libodbc1:i386 but it is not going to be installed
Recommends: libosmesa6:i386 but it is not going to be installed
Recommends: libpcap0.8:i386 but it is not going to be installed
Recommends: libsane:i386 or
libsane1:i386 but it is not going to be installed
Recommends: libv4l-0:i386 but it is not going to be installed
Recommends: libva-drm2:i386 but it is not going to be installed or
libva-drm1:i386 but it is not installable
Recommends: libva-x11-2:i386 but it is not going to be installed or
libva-x11-1:i386 but it is not installable
Recommends: libva2:i386 but it is not going to be installed or
libva1:i386 but it is not installable
Recommends: libxcomposite1:i386 but it is not going to be installed
Recommends: libxslt1.1:i386 but it is not going to be installed
