since a long time , I am having problems whenever I install a package. for example, when i try to install alien package that's what I get:
sudo apt-get install alien
Reading package lists... Done
Building dependency tree
alien is already the newest version (8.95).
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [O/n] O
Setting up update-notifier-common (3.192.1.7) ...
Traceback (most recent call last):
File "/usr/lib/update-notifier/package-data-downloader", line 24, in  <module>
import debian.deb822
File "/usr/lib/python3/dist-packages/debian/deb822.py", line 38, in  <module>
import chardet
ModuleNotFoundError: No module named 'chardet'
dpkg: error processing package update-notifier-common (--configure):
installed update-notifier-common package post-installation script     subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of update-notifier:
update-notifier depends on update-notifier-common (= 3.192.1.7); however:
Package update-notifier-common is not configured yet.
dpkg: error processing package update-notifier (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of ubuntu-desktop:
ubuntu-desktop depends on update-notifier; however:
Package update-notifier is not configured yet.
dpkg: error processing package ubuntu-desktop (--configure):
dpkg: dependency problems prevent configuration of update-manager:
update-manager depends on update-notifier; however:
dpkg: error processing package update-manager (--configure):
No apport report written because the error message indicates it's a follow-up error from a previous failure.
No apport report written because MaxReports has already been reached
update-notifier
ubuntu-desktop
update-manager
j'ai essayé de fixer les paquets en supprimant mais le problème persiste
enter code here
sudo apt-get autoremove
import chardet
 update-notifier
 ubuntu-desktop
 update-manager
I encountered the same problem today. After a number of searches on the Stack Overflow site, no desired solution was found. However, I found a solution after searching on a Chinese website, and below are the solution:
cd /var/lib/dpkg
sudo mv info info.bak
sudo mkdir info
sudo apt-get upgrade
Ref here
hchen98
  • 141
after
cd /var/lib/dpkg
sudo mkdir info
you should put the original info directory back in place so that the package management system can track installed packages correctly:
sudo mv /var/lib/dpkg/info /var/lib/dpkg/info.replacement
sudo mv /var/lib/dpkg/info.bak /var/lib/dpkg/info
sudo dpkg --configure -a
sudo apt clean && sudo apt update && sudo apt upgrade
sudo apt autoremove && sudo apt install -f
