Getting the following error attempting to run an apt-get update in prep for a package install:
chris@chris-X1C6:/etc/apt$ sudo apt-get update
Hit:1 http://ppa.launchpad.net/teejee2008/ppa/ubuntu bionic InRelease
Err:2 http://mirror.picosecond.org/ubuntu bionic InRelease
Could not connect to mirror.picosecond.org:80 (2001:470:1:12e::133). - connect (101: Network is unreachable) Could not connect to mirror.picosecond.org:80 (184.105.204.133), connection timed out
Err:3 http://mirror.picosecond.org/ubuntu bionic-updates InRelease
Unable to connect to mirror.picosecond.org:http:
Err:4 http://mirror.picosecond.org/ubuntu bionic-backports InRelease
Err:5 http://mirror.picosecond.org/ubuntu bionic-security InRelease
Reading package lists... Done
W: Failed to fetch http://mirror.picosecond.org/ubuntu/dists/bionic/InRelease Could not connect to mirror.picosecond.org:80 (2001:470:1:12e::133). - connect (101: Network is unreachable) Could not connect to mirror.picosecond.org:80 (184.105.204.133), connection timed out
W: Failed to fetch http://mirror.picosecond.org/ubuntu/dists/bionic-updates/InRelease Unable to connect to mirror.picosecond.org:http:
W: Failed to fetch http://mirror.picosecond.org/ubuntu/dists/bionic-backports/InRelease Unable to connect to mirror.picosecond.org:http:
W: Failed to fetch http://mirror.picosecond.org/ubuntu/dists/bionic-security/InRelease Unable to connect to mirror.picosecond.org:http:
W: Some index files failed to download. They have been ignored, or old ones used instead.
Doing a bit of googling this seems to be most commonly related to proxy settings. I have installed a proxy via Firefox since I can last recall running apt-get update successfully, but it's not currently active, and even when it is, I'm not seeing any proxy specified:
chris@chris-X1C6:/etc/apt$ env | grep -i proxy
I've also tried running apt-get update setting the proxy option to false as described in this post (as I don't appear to have an apt.conf file):
sudo apt-get update -o Acquire::http::Proxy="false"
with the same results.
Any ideas what might be causing this and how to fix.
