I wrote a command line application that does this.
The easiest way to get started is download the app from the releases page and run
$ ./bat --help
from the terminal in the directory where it is located which should show the help documentation.
If there's an error, it might have to do with permissions. The following command might solve the problem.
chmod +x ./bat
Basically, running
$ ./bat --threshold
will print out the current threshold.
To set a new threshold, say 60%, run
./bat --threshold 60
To persist the current threshold between restarts, run
sudo ./bat --persist
Note: Persisting uses systemd under the hood but this is bundled with most Linux distributions including Ubuntu.
Tip: Putting the app in a directory like /usr/local/bin/ that is in the $PATH will enable you to run it from anywhere and not just in the directory the app is in. Then the above commands become,
bat --help
bat --threshold 60
bat --persist
respectively.
