I'd like to replace wpa_supplicant with iwd and use it for my wifi networking. This is so that I can use and test Network Manager using iwd. I can't seem to find instructions around relating to Ubuntu this anywhere.
If you read the 19.04 release notes, it says:
IWD can now be enabled for use with Network Manager. IWD is a new alternative to wpa supplicant and is in testing for consideration in the future.
psiphi75
  • 976
I found the following works.
sudo apt install iwd
and create a new file called /etc/NetworkManager/conf.d/iwd.conf and add the following:
[device]
wifi.backend=iwd
Then disable wpa supplicant:
sudo systemctl mask wpa_supplicant
sudo reboot
Thanks to the ever-useful Arch wiki.
Update: Ubuntu are now testing iwd for their 20.10 release.
psiphi75
  • 976
