I have a folder with ~30 files. The are already BitTorrent metafiles that lack a .torrent suffix. I want to change all those files to .torrent files. How would I do that? In windows it was as easy as typing
ren *.* *.torrent
while being inside the folder with all those files.
I am not sure what the current file extension of those 30 files is.
Appreciate any help!
If you can install rename:
sudo apt install rename
Try:
rename 's/\.[a-zA-Z0-9]{1,}$/.torrent/' *.*
On another note, remember changing file extension won't change its file type or contents.
for file in *; do
  base=`echo "${file%.*}"`
  mv -- "${file}" "${base}.torrent"
done
Worked for me!
sudo apt install krusader krename
Krusader has a menu for File-MultiRename on selected files in it's browser, which browser also can be filtered . krename can also be used in terminal and it's own gui when run without parameters.
pierrely
  • 725
