I'm seeing a strange issue of No Bluetooth devices not being discovered after a restart.
I upgraded my machine from 16.04 to 18.04 and I was just happy that bluetooth is working with the latest.
PS: I have also tried multiple solutions like
  1. Restarting the machine
  2. Restarting bluetooh through commandline
  3. Also copy pased and ran a few commands posted in the few answers mentioned already
Here is the screenshot of bluetooth searching for devices forever
rfkill list 16:32:24 0: phy0: Wireless LAN Soft blocked: no Hard blocked: no 1: brcmwl-0: Wireless LAN Soft blocked: no Hard blocked: no 2: hci0: Bluetooth Soft blocked: no Hard blocked: no
Edit:
hciconfig --all hci0: Type: Primary Bus: USB BD Address: 08:ED:B9:92:B8:6E ACL MTU: 1021:8 SCO MTU: 64:1 UP RUNNING PSCAN ISCAN INQUIRY RX bytes:1868 acl:0 sco:0 events:137 errors:0 TX bytes:5788 acl:0 sco:0 commands:131 errors:0 Features: 0xff 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87 Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3 Link policy: RSWITCH HOLD SNIFF Link mode: SLAVE ACCEPT Name: 'sujeet-pc' Class: 0x1c010c Service Classes: Rendering, Capturing, Object Transfer Device Class: Computer, Laptop HCI Version: 4.0 (0x6) Revision: 0x0 LMP Version: 4.0 (0x6) Subversion: 0x210b Manufacturer: Broadcom Corporation (15)
Edit 2: brcm dmesg | grep Blue [ 34.529720] Bluetooth: Core ver 2.22 [ 34.529738] Bluetooth: HCI device and connection manager initialized [ 34.529741] Bluetooth: HCI socket layer initialized [ 34.529743] Bluetooth: L2CAP socket layer initialized [ 34.529746] Bluetooth: SCO socket layer initialized [ 39.262414] Bluetooth: hci0: BCM: chip id 70 [ 39.263363] Bluetooth: hci0: BCM: features 0x06 [ 39.279373] Bluetooth: hci0: BCM43142A [ 39.279380] Bluetooth: hci0: BCM (001.001.011) build 0000 [ 39.475850] Bluetooth: hci0: BCM: Patch brcm/BCM.hcd not found [ 50.855282] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 50.855284] Bluetooth: BNEP filters: protocol multicast [ 50.855288] Bluetooth: BNEP socket layer initialized [ 53.760056] Bluetooth: hci0: command 0x1003 tx timeout [ 170.970381] Bluetooth: RFCOMM TTY layer initialized [ 170.970392] Bluetooth: RFCOMM socket layer initialized [ 170.970399] Bluetooth: RFCOMM ver 1.11 [ 1930.483146] Bluetooth: hci0: BCM: chip id 70 [ 1930.484135] Bluetooth: hci0: BCM: features 0x06 [ 1930.500145] Bluetooth: hci0: BCM43142A [ 1930.500149] Bluetooth: hci0: BCM (001.001.011) build 0000 [ 1930.500168] Bluetooth: hci0: BCM: Patch brcm/BCM.hcd not found [ 1932.533242] Bluetooth: hci0: command 0x1003 tx timeout
also, Contents of the exisistig brcm folder
➜ brcm ls -la total 16580 drwxr-xr-x 2 root root 4096 Aug 1 14:42 . drwxr-xr-x 85 root root 36864 Aug 1 14:42 .. -rw-r--r-- 1 root root 269595 Mar 30 2017 bcm4329-fullmac-4.bin -rw-r--r-- 1 root root 96224 Mar 30 2017 bcm43xx-0.fw -rw-r--r-- 1 root root 180 Mar 30 2017 bcm43xx_hdr-0.fw -rw-r--r-- 1 root root 397312 Mar 30 2017 brcmfmac43143.bin -rw-r--r-- 1 root root 385067 Nov 17 2017 brcmfmac43143-sdio.bin -rw-r--r-- 1 root root 348160 Mar 30 2017 brcmfmac43236b.bin -rw-r--r-- 1 root root 455745 Mar 30 2017 brcmfmac43241b0-sdio.bin -rw-r--r-- 1 root root 403855 Mar 30 2017 brcmfmac43241b4-sdio.bin -rw-r--r-- 1 root root 408682 Mar 30 2017 brcmfmac43241b5-sdio.bin -rw-r--r-- 1 root root 479232 Mar 30 2017 brcmfmac43242a.bin -rw-r--r-- 1 root root 253748 Mar 30 2017 brcmfmac4329-sdio.bin -rw-r--r-- 1 root root 222126 Mar 30 2017 brcmfmac4330-sdio.bin -rw-r--r-- 1 root root 402210 Jul 12 20:24 brcmfmac43340-sdio.bin -rw-r--r-- 1 root root 451566 Mar 30 2017 brcmfmac4334-sdio.bin -rw-r--r-- 1 root root 569291 Mar 30 2017 brcmfmac4335-sdio.bin -rw-r--r-- 1 root root 219557 Jul 12 20:24 brcmfmac43362-sdio.bin -rw-r--r-- 1 root root 562183 Jul 12 18:00 brcmfmac4339-sdio.bin -rw-r--r-- 1 root root 382455 Apr 25 2018 brcmfmac43430a0-sdio.bin -rw-r--r-- 1 root root 369577 Jul 12 20:24 brcmfmac43430-sdio.bin -rw-r--r-- 1 root root 488193 Mar 30 2017 brcmfmac43455-sdio.bin -rw-r--r-- 1 root root 623304 Nov 17 2017 brcmfmac4350c2-pcie.bin -rw-r--r-- 1 root root 626140 Mar 30 2017 brcmfmac4350-pcie.bin -rw-r--r-- 1 root root 626589 Jul 12 20:24 brcmfmac4354-sdio.bin -rw-r--r-- 1 root root 557056 Mar 30 2017 brcmfmac43569.bin -rw-r--r-- 1 root root 661999 Jul 12 20:24 brcmfmac4356-pcie.bin -rw-r--r-- 1 root root 526383 Nov 17 2017 brcmfmac4356-sdio.bin -rw-r--r-- 1 root root 550333 Mar 30 2017 brcmfmac43570-pcie.bin -rw-r--r-- 1 root root 633817 Jul 12 18:00 brcmfmac4358-pcie.bin -rw-r--r-- 1 root root 595472 Nov 17 2017 brcmfmac43602-pcie.ap.bin -rw-r--r-- 1 root root 635449 Nov 17 2017 brcmfmac43602-pcie.bin -rw-r--r-- 1 root root 989401 Jul 12 20:24 brcmfmac4366b-pcie.bin -rw-r--r-- 1 root root 1120971 Jul 12 18:12 brcmfmac4366c-pcie.bin -rw-r--r-- 1 root root 623448 Mar 30 2017 brcmfmac4371-pcie.bin -rw-r--r-- 1 root root 479232 Apr 25 2018 brcmfmac4373.bin -rw-r--r-- 1 root root 457994 Apr 25 2018 brcmfmac4373-sdio.bin
Edit 3:lsusb | grep -i blue lsusb | grep -i blue
Bus 001 Device 003: ID 0a5c:21d7 Broadcom Corp. BCM43142 Bluetooth 4.0
Edit 4: sudo systemctl status bluetooth
 bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2019-08-04 22:09:10 IST; 2s ago
     Docs: man:bluetoothd(8)
 Main PID: 9555 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4915)
   CGroup: /system.slice/bluetooth.service
           └─9555 /usr/lib/bluetooth/bluetoothd
Aug 04 22:09:10 sujeet-pc systemd[1]: Starting Bluetooth service...
Aug 04 22:09:10 sujeet-pc bluetoothd[9555]: Bluetooth daemon 5.50
Aug 04 22:09:10 sujeet-pc systemd[1]: Started Bluetooth service.
Aug 04 22:09:10 sujeet-pc bluetoothd[9555]: Starting SDP server
Aug 04 22:09:10 sujeet-pc bluetoothd[9555]: Bluetooth management interface 1.14 initialized
Make sure linux-firmware is installed.
Control with dmesg | grep Blue that your bluetooth find his firmware. Should similiar look like mine Bluetooth: hci0: BCM20702A If the firmware is missing, you can download it from git
and move it in the folder /lib/firmware/brcm/
nobody
  • 5,792
Yes, I fixed my bluettoh problem. It took only 5 mins to do with attention.
here is the link https://medium.com/@sujeetb/how-i-fixed-my-bluetooth-issue-in-ubuntu-18-04-lts-805c865fa87
