So this is in addendum to my question posed here. Thank you to @dessert who helped a lot with that question.
So I am trying to authenticate a Gitlab user by using their username and password, and not by creating an impersonation token. At the moment, the code that @dessert has created that uses an impersonation token to authenticate a user is as such:
$ curl -d '{"title":"test key","key":"'"$(cat ~/.ssh/id_rsa.pub)"'"}' -H 'Content-Type: application/json' https://gitlab.com/api/v4/user/keys?private_token=<my_access_token>
Mainly focusing on the `private_token=, except with the creation of an impersonation token found here
$ curl --request POST --header "PRIVATE-TOKEN: <your_access_token>" --data "name=mytoken" --data "expires_at=2017-04-04" --data "scopes[]=api" https://gitlab.example.com/api/v4/users/42/impersonation_tokens
I want to be able to use the username and password of the Gitlab user to authenticate them. I've seen this done with Github, and have done it myself:
$ curl -u "USERNAME:PASSWORD" --data "{\"title\": \"TITLE\", \"key\": \"$(cat ~/.ssh/id_rsa.pub)\"}" https://api.github.com/user/keys
Where USERNAME and PASSWORD are authenticating by user-inputted username and password.
I don't need help with reading input of the user; that's not the issue. My issue (to sum up) is to be able to authenticate a Gitlab user through their username and password.
Again, thanks to @dessert for the help, and any other assistance is appreciated!!
A quick edit: I found this forum post for authentication with login and password, and most are saying to use a Personal Access Token. Does this mean I have to get the user to give me their PAT for authentication? Or do I provide my PAT and somehow it does something? (I was a little unclear on this)
