To upgrade to the latest version, please do the following:
Add the Ubuntu repository that contains the latest version 0.9.3-2, run the following command in terminal:
echo "deb http://cz.archive.ubuntu.com/ubuntu eoan main universe" | sudo tee -a /etc/apt/sources.list
Update the repositories, run the following command in terminal:
sudo apt update
Upgrade to the latest version, run the following command in terminal:
sudo apt install liburiparser-dev
After this you should have the latest liburiparser-dev installed.
CAUTION:
At the moment 19.10 (Eoan) is pre-release -- it's still in testing. If you run into problems, we don't provide support for pre-release here. Also, one of the most common problems we help untangle is folks who have mixed sources from different releases of Ubuntu and broke their system, so we usually don't recommend it. Folks who want newer software should use a newer release of Ubuntu instead. It is strongly advised to just upgrade the needed package and remove the repository added above, once you have successfully upgraded the needed package. This can be done by editing the /etc/apt/sources.list file and commenting out or removing that line and running sudo apt update afterwards.
NOTE:
To know which official Ubuntu repository contains the latest version of a certain package, you can search for it at Ubuntu packages.
