21
Recently I deleted the folder Desktop from my $HOME directory. When I logged in again all files and directories in $HOME were shown on the desktop. So I wanted to get the folder back. What is the recommended way to achieve this? I edited ~/.config/xdg-user-dirs.dir and added the correct variable. But I guess there must be some other (more easy?) way.
qbi
  • 19,515
  1. Create a new folder that you want to use as your folder.
    For example, type mkdir ~/Desktop in a terminal (Ctrl+Alt+T to open one) to create a folder named Desktop in your home directory.
  2. Edit your configuration.
    Edit the file ~/.config/user-dirs.dirs. You can do this by opening a terminal, then enter:
    gedit ~/.config/user-dirs.dirs
    Change the entry for XDG_DESKTOP_DIR to your new desktop folder, or add it, if the entry does not exist. After your edit, the file should look like this:
    XDG_DESKTOP_DIR="$HOME/Desktop"
    XDG_DOWNLOAD_DIR="$HOME/Download"
    XDG_TEMPLATES_DIR="$HOME/Templates"
    XDG_PUBLICSHARE_DIR="$HOME/Public"
    XDG_DOCUMENTS_DIR="$HOME/Documents"
    XDG_MUSIC_DIR="$HOME/Music"
    XDG_PICTURES_DIR="$HOME/Pictures"
    XDG_VIDEOS_DIR="$HOME/Videos"
  3. Log out and then log in again and your desktop should show the specified folder.
Eliah Kagan
  • 119,640
mrcktz
  • 1,774
You can use xdg-user-dirs-update command to set Desktop.
 xdg-user-dirs-update --set DESKTOP $HOME/NewDesktop
But at first check out your locale names
 cat  ~/.config/user-dirs.dirs
For English locale they are:
 XDG_DOWNLOAD_DIR="$HOME/Downloads"
You can set any of the above
 xdg-user-dirs-update --set DOWNLOAD ~/Internet
in order for the changes to take effect nautilus -q.
For more info check out https://wiki.archlinux.org/index.php/XDG_user_directories
kenn
  • 5,232
In my case after updating gedit ~/.config/user-dirs.dirs was not worked. Because there was as symbolic link '../Desktop' in system and that had been broken (i think after update). I simply deleted that symbolic link and created new directory and edited gedit ~/.config/user-dirs.dirs
Just create an new folder with the name Desktop.
ohno
  • 833
