36
I have a machine running Ubuntu 18.04 LTS where I cannot seem to get SSH Server working.
I installed SSHServer using:
sudo apt install openssh-server
but I am getting the following when I try to start and / or check the status:
sudo systemctl start sshd
Failed to start sshd.service: Unit sshd.service not found.
sudo systemctl status sshd
Unit sshd.service could not be found.
I figured I must have done something wrong (typo?) when I installed, so I tried to install again thus:
to which I get:
Reading package lists... Done
Building dependency tree
openssh-server is already the newest version (1:7.6p1-4ubuntu0.3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
So, it appears it is installed, but for some reason Ubuntu cannot find it.
I am not sure where to go from here, so any suggestions would be welcome.
Thanks,
Alan.
Alan
  • 999
It is possible that the service is not called sshd. you can try this command
systemctl -l --type service --all|grep ssh
On my ubuntu 18.04, the service is called ssh by default.
in my case, I did
If that doesn't solve your problem, you can reinstall ssh
sudo apt-get remove --purge openssh-server
sudo apt-get update
sudo apt-get install openssh-server
This solved issue in my case.
sudo systemctl enable ssh
Check also: https://www.cyberciti.biz/faq/ubuntu-linux-install-openssh-server/
luka
