I was trying to install mysql for npm with the comand npm install mysql, then I receive this error message:
npm WARN npm npm does not support Node.js v10.15.2
npm WARN npm You should probably upgrade to a newer version of node as we
npm WARN npm can't make any promises that npm will work with this version.
npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
npm WARN npm You can find the latest version at https://nodejs.org/
npm WARN using --force I sure hope you know what you are doing.
My version of node.js is 10.15.2 and the version of npm is 5.8.0. I think the problem is that they are not compatible. I was trying to update node, but I didn't succed in it. Solutions?
I have switched to a newer version of nodejs, the twelve one, with this code:
curl -sL https://deb.nodesource.com/setup_11.x | sudo -E bash -
sudo apt-get install -y nodejs
The problem is that I still can't download mysql for npm. The message is:
npm WARN saveError ENOENT: no such file or directory, open '/home/dario/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/home/dario/package.json'
npm WARN dario No description
npm WARN dario No repository field.
npm WARN dario No README data
npm WARN dario No license field.
+ mysql@2.17.1
updated 1 package and audited 32 packages in 1.447s
found 0 vulnerabilities
wjandrea
  • 14,504
Well i face the same problem today after install ubuntu 19.10. and i solve this by updating npm using below command
npm install -g npm@latest
For more details you can check this issue in github
npm version issue
Hope it will help
sayalok
  • 301
You can install the latest LTS Node.js on Ubuntu using the following command:
curl -fsSL https://deb.nodesource.com/setup_lts.x | sudo -E bash -
This method is indicated in the official documentation.
Node.js binary distributions
If you need many versions of nodejs at the same time Recommend using nvm (git nvm) install
curl -o- https://raw.githubusercontent.com/nvm-sh/nvm/v0.39.0/install.sh | bash
Example of use
install 16 node
nvm install 16
list of installed
nvm ls
Selection of the version you need at the moment
nvm use 16
This way you can easily change the version. For compatibility with project packages.
F00x
  • 17
