Is it sufficient to have one of these three in Ubuntu 19.04? Is it possible to have all three and how to configure them so they were not conflicting?
Does systemd-networkd started by networking.service?
As you might know /etc/network/interfaces has been replaced with netplan. And netplan works fine with both NetworkManager and systemd-networkd.
So you can have them all work together!
If you're running Ubuntu as your desktop, then you should use NetworkManager or config netplan so it uses NetworkManager as its default renderer:
network:
version: 2
renderer: NetworkManager
Otherwise you can easily setup your interfaces in netplan itself, for example to have interfaces like configuration and network-manager work together:
network:
version: 2
wifis:
wlp4s0:
dhcp4: yes
access-points:
my-access-point:
password: passw00rd
network:
version: 2
renderer: networkd
ethernets:
enp3s0:
addresses:
- 192.168.1.10/24
dhcp4: false
dhcp6: false
gateway4: "192.168.1.1"
nameservers:
addresses:
- "8.8.4.4"
- "8.8.8.8"
Configuration
To configure netplan, save configuration files under /etc/netplan/ with a .yaml extension (e.g. /etc/netplan/config.yaml), then run sudo netplan apply. This command parses and applies the configuration to the system. Configuration written to disk under /etc/netplan/ will persist between reboots.
Netplan configuration examples
Replacing netplan with ifupdown is still possible but something that I wouldn't suggests.
ifupdownnetplaninterfaces/etc/NetworkManager/NetworkManager.conf so it would be able to manage your interfaces.You can even run dhclient directly to bring an interface up.
