I have a 64-bit 19.04 installation, but if I attempt to install a 32-bit package (wine32 for example), I'm given this message:
with a list of i386 packages. If I attempt to install those, I'm often given an even longer list of i386 packages that I'm missing. I could go through and recursively keep attempting to install these i386 packages, but there must be some other way.
Most suggestions I've seen online are to run sudo dpkg --add-architecture i386, but this has had no effect. I'm not quite sure what I'm doing wrong.
This is the contents of my /etc/apt/sources.list, if there's something I'm missing from here either:
deb http://archive.ubuntu.com/ubuntu disco main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu disco-security main restricted universe multiverse
deb http://archive.canonical.com/ubuntu disco partner
