Every time I try to edit the grub file it does not let me save it. It says "access denied" or, in a different editor:
Object not accessible. The object cannot be accessed due to insufficient user rights.
Sometimes it does not let me edit it, and this frustrates me as I need to edit it for my Wacom tablet to work.
How can I save my edited grub file? I saw a YouTube video on "Wacom on ubuntu: How to run your tablet on Ubuntu and Ubuntu LiveUSB - Wacom One" but I don't know if that works.
Eliah Kagan
  • 119,640
grub is a system owned application so you need to use sudo to edit the file:
sudo -H gedit /etc/default/grub
If you omit sudo -H you can view the file but not save any changes.
After editing the file you need to run:
sudo update-grub
This will compile the changes you made to /etc/default/grub and compile them with grub functions to create a new /boot/grub/grub.cfg which is the actual file parsed at boot time.
Note: Related question today: How do I edit configuration files?
Eliah Kagan
  • 119,640
