21
EDIT: This is not a duplicate as this question is the reverse of what the other question is asking. Here we know what is the application and we want to find its .desktop file that can be located in non standard places also. While the other question is about where the .desktop files can be placed.
I want to open images from an FTP server in the default image viewer rather than in the browser, so I wanted to know the path of default image viewer desktop file in Ubuntu. I tried the following:
cd -- /usr/share/applications
$ find . -name '*.desktop' | grep image
./gnome-disk-image-mounter.desktop
./gnome-disk-image-writer.desktop
$ find . -name '*.desktop' | grep view
./calibre-ebook-viewer.desktop
./calibre-lrfviewer.desktop
./evince-previewer.desktop
./shotwell-viewer.desktop
./okularApplication_ghostview.desktop
./gcr-viewer.desktop
./gnome-info-overview-panel.desktop
./org.gnome.font-viewer.desktop
./paraview.desktop
But I still couldn't find it. Are there any other locations where the desktop files are stored?
Porcupine
  • 739
A much faster and more universal search is with locate command:
$ locate '*image*desktop'
/usr/share/app-install/desktop/gimagereader:gimagereader-gtk.desktop
/usr/share/app-install/desktop/gnome-disk-utility:gnome-disk-image-mounter.desktop
/usr/share/app-install/desktop/gnome-disk-utility:gnome-disk-image-writer.desktop
/usr/share/app-install/desktop/imagej:imagej.desktop
/usr/share/app-install/desktop/imagemagick-6.q16:display-im6.q16.desktop
/usr/share/app-install/desktop/imagemagick:display-im6.desktop
/usr/share/app-install/desktop/imagevis3d:imagevis3d.desktop
/usr/share/app-install/desktop/kimagemapeditor:kde4__kimagemapeditor.desktop
/usr/share/app-install/desktop/simple-image-reducer:simple-image-reducer.desktop
/usr/share/app-install/desktop/trimage:trimage.desktop
/usr/share/applications/gnome-disk-image-mounter.desktop
/usr/share/applications/gnome-disk-image-writer.desktop
/usr/share/applications/screensavers/tessellimage.desktop
locate can search millions of files in a few seconds where it would take find many many minutes:
$ time find / -name '*image*.desktop'
real    0m52.563s
user    0m6.271s
sys     0m9.002s
$ time locate 'imagedesktop' real 0m0.705s user 0m0.693s sys 0m0.012s
Notice how grep was eliminated from original method and find command was ammended.
The disadvantage of locate is the database is updated daily. If you just installed the application you are searching for today, you will first need to run:
sudo updatedb
Installation
In newer versions of Ubuntu, you can install locate by installing the package plocate:
sudo apt install plocate
Flimm
  • 44,031
10
Search .desktop launchers by their content
The name of the desktop file alone may not reveal sufficient information. The fundamental approach is to search the content of all .desktop files of the system to find the relevant one(s).
For example, the image viewer is displayed as Image Viewer in the Applications overview. Gnome Shell obtained that label from the .desktop file. To find the .desktop file (or files) that contains this string, execute
find / -name '*.desktop' -exec grep -H 'Image Viewer' {} \; 2>/dev/null
This uses find to find all .desktop files on the system. For each of the found files, grep is invoked, which searches for a string in the file, in this example Image Viewer. The 2>/dev/null suppresses the permission errors you inevitably get searching the root drive without root permissions.
Desktop launcher search order
Multiple .desktop launchers with the same name may exist on the system. The one that is in use depends on where it resides.
The system first searches .desktop files in your local ~/.local/share/applications directory, and then searches applications directories that exist under the directories included in the variable $XDG_DATA_DIRS.
For example, the contents of XDG_DATA_DIRS can be displayed as follows
$ printenv XDG_DATA_DIRS
/usr/share/ubuntu: /usr/local/share/:/usr/share/:/var/lib/snapd/desktop
The system first searches ~/.local/share/applications, then /usr/share/ubuntu/applications etc. .desktop launchers with the same name further in this search path, or elsewhere on the system, are not used.
vanadium
  • 97,564
Well my solution is very easy and here is how you do it if you are looking for the application with a icon in your apps
ls -la /usr/share/applications | grep <name_of_app_you_are_looking_for>
for Example i want to find location for some apps in my Ubuntu --- i want to find the desktop file for Google Chrome enter image description here
But it only works for the apps inside /usr/share/applications
Here is a small perl script that will search XDG_DATA_DIRS for desktop files for programs of a given name match. It also lists the Exec= line(s) in any found .desktop files, because that's usually what I am trying to find out. For example, to find the program whose name shows as GNU Image Manipulation Program:
$ ./findDesktopFile.pl GNU Im
/usr/share/applications/gimp.desktop
Exec=gimp-2.10 %U
Here is the code.
#!/usr/bin/perl
use warnings;
use warnings 'FATAL' => 'all';
use strict;
my $prog = '';
my $places = $ENV{XDG_DATA_DIRS} =~ s/:/ /gr;
while (@ARGV)
    $prog .= ' ' . shift(@ARGV);
$prog =~ s/^ //;
open(FIND, "find $places -type f -name '*.desktop' -exec grep -l 'Name=$prog' {} + 2>/dev/null |");
while (my $file = <FIND>)
    print $file;
    chomp $file;
    system "grep ^Exec= $file";
close FIND;
muru
  • 207,228
