I want to install rabbitmq on my Ubuntu 18.04. I have been following the official documentation. However, my installation is not completed as I am getting stuck on the step: sudo apt-get install rabbitmq-server -y --fix-missing as I face an error: unmet dependencies.
I tried installing libssl and then erlang-crypto, didn't work. I also installed aptitude using which I tried installing erlang-crypto, it also didn't install any package.
The command that I am running is:
sudo apt-get install -y erlang-base \
                        erlang-asn1 erlang-crypto erlang-eldap erlang-ftp erlang-inets \
                        erlang-mnesia erlang-os-mon erlang-parsetools erlang-public-key \
                        erlang-runtime-tools erlang-snmp erlang-ssl \
                        erlang-syntax-tools erlang-tftp erlang-tools erlang-xmerl
I get a failure message:
Reading package lists... Done
Building dependency tree
 erlang-crypto : Depends: libssl1.1 (>= 1.1.1) but it is not installable
The libssl package isn't available and I have successfully installed libssl-dev.
I expect to completely install RabbitMQ and it runs successfully.
