My computer is a Dell XPS laptop.
I was able to us my Ubuntu 19.04 installation without any problems, but today while working it started to act strange. Every command I would enter into the terminal resulted in permission denied. So I decided to reboot.
I would then enter the password to decrypt the partion, and then it would go to a blank screen, sometimes with a static _ in the upper left corner.
Things I tried
  • Changed /etc/default/grub from GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" to GRUB_CMDLINE_LINUX_DEFAULT=""
  • Tried purging nvidia, but nothing was removed, presumably because it wasn't installed.
  • So I tried to install the Nvidia graphics driver with sudo apt install nvidia-driver-390. This slightly changed the result, but only slightly. Now the screen is almost blank, with the exception of a green OK in the corner. However, on subsequent reboots I now no longer get the green OK. I just get a static _.
    Output from hwinfo --gfxcard --short:
    nvidia GP107M [Geforce GTX 1050 Ti Mobile]
    Intel UHD Graphics 630 Mobile
  • I tried sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.mybak but get /etc/X11/xorg.conf no such file or directory.
  • Tried sudo apt-get remove --purge nvidia-*. And this uninstalled a lot of stuff!
  • Tried sudo apt-get remove --purge xserver-xorg-video-nouveau but this E: Unable to locate package xserver-xorg-video-nouveau
  • Tried sudo apt-get install xserver-xorg-video-nouveau but this E: Unable to locate package xserver-xorg-video-nouveau
  • Tried sudo dpkg-reconfigure xserver-xorg - but nothing happened.
  • Tried sudo chmod a-x /usr/bin/compiz and get cannot access /usr/bin/compiz: No such file or directory. From https://wiki.ubuntu.com/X/Troubleshooting/BlankScreen#Analysis_Techniques
  • Tried sudo rm /lib/firmware/amdgpu_raven_dmcu.bin but got No such file or directory
  • Tried sudo apt-get install nvidia-current but got E: Package nvidia-current has no installation candidate
  • Tried: sudo apt-get install --reinstall linux-headers-$(uname -r) and then sudo apt-get install --reinstall linux-image-$(uname -r). Then reboot, but still the same issue remains. From https://ubuntuforums.org/showthread.php?t=1744248&p=10744546#post10744546
  • Tried setting acpi=off in grub. This results in the boot sequence hanging at Freeing unused kernel image memory 2576k. I also tried pci=noacpi. This didnt change the result. I also tried setting acpi=strict. This also didnt change the result. From https://askubuntu.com/a/962099/17643
  • Tried setting apm=off. This didnt change the result. From https://www.linuxquestions.org/questions/linux-software-2/hang-after-freeing-unused-kernel-memory-211275/#post1384593
  • Tried each of the following, individually: nolapic, noapic, acpi_osi=“Linux”, acpi=ht, acpi=noirq and pnpacpi=off. These didnt change the result, except for the last one which resulted in a stream of errors. From https://askubuntu.com/a/406419/17643
  • Tried to recover files using a live cd, and using sudo ecryptfs-recover-private but the live cd doesnt have ecryptfs-recover-private - instead I get command not found. Does anyone know where I can get a Live CD that has ecryptfs-recover-private or where I can install this utility from?
Magick
  • 172
