Everytime I try to install vim, I get this strange problem:
cuda-libraries-dev-10-1 : Depends: libcublas-dev (>= 10.2.0.168) but it is not going to be installed
cuda-samples-10-1 : Depends: libcublas-dev (>= 10.2.0.168) but it is not going to be installed
cuda-visual-tools-10-1 : Depends: libcublas-dev (>= 10.2.0.168) but it is not going to be installed
vim : Depends: vim-runtime (= 2:8.0.1453-1ubuntu1.1) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Frankly I made a mess of installing CUDA, so I'm wondering if these messages mean that I've broken anything. If not, why can't vim install?
Here is the output of sudo apt--fix-broken install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
g++-6 libaccinj64-9.1 libcublas9.1 libcudart9.1 libcufft9.1 libcufftw9.1 libcuinj64-9.1 libcurand9.1
libcusolver9.1 libcusparse9.1 libnppc9.1 libnppial9.1 libnppicc9.1 libnppicom9.1 libnppidei9.1
libnppif9.1 libnppig9.1 libnppim9.1 libnppist9.1 libnppisu9.1 libnppitc9.1 libnpps9.1 libnvblas9.1
libnvgraph9.1 libnvrtc9.1 libnvtoolsext1 libnvvm3 libstdc++-6-dev libthrust-dev libvdpau-dev
nvidia-cuda-dev nvidia-cuda-doc nvidia-cuda-gdb nvidia-opencl-dev nvidia-profiler
nvidia-visual-profiler ocl-icd-opencl-dev opencl-c-headers openjdk-8-jre
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libcublas-dev
The following NEW packages will be installed:
libcublas-dev
0 upgraded, 1 newly installed, 0 to remove and 53 not upgraded.
35 not fully installed or removed.
Need to get 0 B/39.1 MB of archives.
After this operation, 112 MB of additional disk space will be used.
