I'm trying to install mongoDB on my Ubuntu 14
The first step was this
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 7F0CEB10
But it showed me below error
    Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.lAXAyfkEwA --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyring /etc/apt/trusted.gpg.d/linuxuprising-java.gpg --keyring /etc/apt/trusted.gpg.d/openjdk-r-ppa.gpg --keyring /etc/apt/trusted.gpg.d/webupd8team-java.gpg --keyserver hkp://keyserver.ubuntu.com:80 --recv 7F0CEB10
gpg: requesting key 7F0CEB10 from hkp server keyserver.ubuntu.com
?: server: Host not found
gpgkeys: HTTP fetch error 7: couldn't connect: Connection timed out
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
I googled, got to know that's destination is somewhere where my machine is not able to make succesful request. Need to use proxy.
Came to this post
https://askubuntu.com/questions/147311/no-gpg-key-from-behind-a-firewall
It says add Acquire::http::Proxy "http://user:password@server:port"; in apt.conf file and try, but not success.
Doubt:
1) What's a actual purpose of using GPG keys in using an Database (mongoDb) ?
2) Do I need to add (Acquire::http::Proxy "http://user:password@server:port) as it is or I need to mention my username, server and password in apt.conf file ? If yes, How can I check my server name and port which I need to mention in file ? And username and password is my system's username and password I guess..Right .. ?
Thanks
Update: ping -c 1 keyserver.ubuntu.com return below
PING keyserver.ubuntu.com (91.189.89.49) 56(84) bytes of data. 64 bytes from boquila.canonical.com (91.189.89.49): icmp_seq=1 ttl=50 time=144 ms
--- keyserver.ubuntu.com ping statistics --- 1 packets transmitted, 1 received, 0% packet loss, time 0ms rtt min/avg/max/mdev = 144.294/144.294/144.294/0.000 ms
Jon
They're not used for the database. They are used to verify that the download. Apt uses gpg to sign package metadata, such as size and hashes, to ensure that a malicious mirror cannot feed you malicious packages.
vidarlo
  • 23,497
