I was trying to install R-base but I'm facing unmet dependencies.
I have tried all possible ways to uninstall and install, re-run mongodb services... but nothing worked.
The installation shows an error. Uninstallation doesn't work. This is the error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: mongodb-org-server : Depends: libcurl3 (>= 7.16.2) but it is not going to be installed E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I have tried many solutions from Stack Overflow, but nothing works.
Eliah Kagan
  • 119,640
