First of all, this is not a duplicate of How do I include lines in resolv.conf that won't get lost on reboot?, as
A) It has not been working since 14.04. See the comment:
In 14.04 this answer did nothing for me. – Jay Sullivan Jun 30 '14
B) The answer there is to use /etc/resolvconf/resolv.conf.d/base file, but this question asks exactly why /etc/resolvconf/resolv.conf.d/base file is not working.
Following up on Use dnsmasq as system DNS service, I installed resolvconf as per the latest reply/answer, however, I found that, the /etc/resolvconf/resolv.conf.d/base file, which should be use to preset nameserver values as per all documents that I read, is not doing what is advertised/documented. Here is what the man page says:
File containing basic resolver information. The lines in this file are included in the resolver configuration file even when no interfaces are configured.
However I found that, whatever info I put into the /etc/resolvconf/resolv.conf.d/base file, they would never show up in /etc/resolv.conf.
So just to confirm, is there any way to properly configured nameserver of /etc/resolv.conf for resolvconf?
So far my conclusion is that
- the
127.0.0.1is hard-coded forresolvconfand there is no way to overwrite it. - the only way is to supersede it in
/etc/resolvconf/resolv.conf.d/head, producing twonameservers in/etc/resolv.conffile. One valid and the other invalid (127.0.0.1).
And I truly hope that I'm wrong.
P.S. this is LUbuntu 18.04.2:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.2 LTS
Release: 18.04
Codename: bionic
