14
What is the standard way to turn numlock on by default on startup on lubuntu 10.04?
Lubuntu installs LXDE. I saw some aother solutions for other flavours, but maybe there is a special setting for the lubuntu flavour.
I tried already numlock=0 and numlock=1 in /etc/lxdm/lxdm.conf , but numlock stays off on the next boot.
All other operating systems, also other ubuntu systems, do have numlock turned on on the same machine after booting.
I installed numlockx, and it can change the value, but is this the standard lubuntu way to go? If so, what is the standard place in the lubuntu startup sequene to insert 'numlockx on', how do I set this up correctly?
I also looked at the included lxde keyboard configuration system gui tool, but there are only few options, numlock default not among them.
(Please before you mark this as duplicate consider if it really fits, I could not find this answered in this way. I am interestd to know the standard way for lubuntu (and not kubuntu or gnome) in detail.)
There is also an explanation of the lxdm config file here, but it does not really explain what "lxde numlock suport" means (how could a gui not support numlock?) and what the settings 0 and 1 mean:
http://manpages.ubuntu.com/manpages/lucid/man1/lxdm.1.html
If there is no other LXDE or lubuntu standard way to do it, I am planning to use numlockx and add this line:
/usr/bin/numlockx on
at the beginning of either
/etc/X11/xinit/xinitrc
or
~/.xinitrc
following the instructions found here:
http://www.cyberciti.biz/faq/how-to-linux-turn-on-num-lock-on-gnome-startup/
mit
  • 2,141
5 Answers5
15
Have you tried editing /etc/xdg/lubuntu/lxdm/lxdm.conf instead?
Uncomment # numlock=0 and make it numlock=1
Worked for me :)
More Info:
You need to have "admin" permission (a.k.a. root, or sudo) to make the change, so use...
Works for Lubuntu 16.04:
Go to your "Start button" > System Tools > LXTerminal
In terminal, type: sudo pcmanfm
After entering your password a new folder window will open, it gives you admin/root permission. Click "Up" arrow twice to find /etc folder.
Then navigate to /etc/xdg/lubuntu/lxdm/lxdm.conf
Right-click on lxdm.conf and choose Leafpad to edit and make changes.
To make changes, replace # numlock=0 with numlock=1
Now click Save, and close Leafpad. Done.
You no longer have admin/root permission after window is closed. To "Uncomment" simply means removing # symbol, which will "activate" the command.
teracow
  • 166
bootup numlock for Lubuntu 14.04.1 steps:
  • dl numlockx via synaptic
  • then edit the file /usr/share/lightdm/lightdm.conf.d/50-greeter-wrapper.conf.
Use e.g. this command in a terminal:
sudo gedit /usr/share/lightdm/lightdm.conf.d/50-greeter-wrapper.conf
add this line:
greeter-setup-script=/usr/bin/numlockx on
  • save file and reboot your system
Moi
  • 61
This works for me:
sudo su -
apt-get install numlockx
echo "/usr/bin/numlockx on" >> /etc/xdg/lxsession/Lubuntu/autostart
Best regards!
Costales
  • 2,318
That works for me:
sudo apt-get install numlockx
then restart the PC.
That's all!
Eric Carvalho
  • 55,453
Lubuntu 18.04.02
Open the greater file (with your favorite editor - for me vi):
sudo vi /usr/share/lightdm/lightdm.conf.d/60-lightdm-gtk-greeter.conf
New line just to the end of the file:
Reboot (virtual) machine and at logon you should see green LED for NUM turned on now.
linolino
  • 135
