How do I install the wireless drivers in my Lenovo Legion Y540-15IRH laptop with an Intel 9th Gen. Core i7 CPU?
  • Card-1: Intel Wireless-AC 9560 (Jefferson Peak) driver: iwlwifi
  • Card-2: Realtek is fine with driver r8169 though.
Additional drivers did not show up when I searched. Is there any other driver I need to download from here?
This did not work by the way as mentioned for utils so now I have a search Windows driver that is unnecessary, would that be easy to remove?
Below is the output of commands ran asked for
Output of lspci -nnk | grep -e 0200 - e 0280 -A3:
(standard input):07:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
(standard input)-   Subsystem: Lenovo RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [17aa:38cd]
(standard input)-   Kernel driver in use: r8169
(standard input)-   Kernel modules: r8169
grep: e: No such file or directory
grep: 0280: No such file or directory
Output of rfkill list all:
0: ideapad_wlan: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
1: ideapad_bluetooth: Bluetooth
    Soft blocked: no
    Hard blocked: yes
2: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
3: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
Kulfy
  • 18,154
The key document which explains the use of apt may be helpful. First, the update line tells Ubuntu to check the list of repositories and refresh its list of what's available to download.
 sudo apt update
Next, we tell Ubuntu to get any new items you have installed previously from those repositories.
 sudo apt upgrade
Now that all the current apps and dependencies are up to date, we go get the ndis tools.
 sudo apt install ndisgtk ndiswrapper-utils
Once that's done, then you can proceed with https://mxlinux.org/wiki/networking/ndiswrapper/#Installation
Click Start menu > System > Windows Wireless Drivers
Click on the Install New Driver button and note where you told it to save it to
Navigate to the folder where you stored the downloaded driver folder
Highlight the *.inf file, and click OK
Jump to the Blacklist section below to finish.
K7AAY
  • 17,705
