I have to automate the installation of a Linux image. The perfect behavior would be that I plug the USB, turn on the device and it runs the dd command in order to flash the image stored in the USB into the device. Ideally only the USB port can be used.
What I think maybe could be done is to launch a script from the USB that changes the configuration of the device and copies a .sh file, reboots it and uses that .sh file at the beginning to, using the dd command, flashes the image that is stored in the USB into the device.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
