While trying to connect to a WebDAV server (Nextcloud) I added a faulty address on accident. (See screenshot). This address obviously connects to nowhere, so clicking on it does nothing but bring up an error message. I then tried to remove this faulty connection from the Nautilus sidebar via right click > remove, but the "remove" option is greyed out.
How do I remove the faulty connection from the sidebar?
EDIT: This is the output from /etc/fstab:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/nvme0n1p2 during installation
UUID=eca43126-c653-4637-8917-0be9e08f40d7 /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/nvme0n1p1 during installation
UUID=4A73-C064  /boot/efi       vfat    umask=0077      0       1
/swapfile                                 none            swap    sw              0       0
I also tried unmounting the server manually using gio mount -u since the "volume" in question is correctly listed with gio mount -l. This doesn't produce the desired result, though ("mount point not found").
eka_
The Nextcloud connection is saved in Online Accounts from Ubuntu.
If you remove the account from Settings -> Online Accounts, the faulty mount should go away.
You might need to restart.
pLumo
  • 27,991
