I'm doing
lz@blade:~$ sudo apt-get build-dep gawk
Reading package lists... Done
Building dependency tree
 builddeps:gawk : Depends: libreadline-dev but it is not going to be installed
here's my sources:
deb http://br.archive.ubuntu.com/ubuntu/ bionic main restricted
deb-src http://br.archive.ubuntu.com/ubuntu/ bionic multiverse main universe restricted
deb http://br.archive.ubuntu.com/ubuntu/ bionic universe
deb-src http://security.ubuntu.com/ubuntu bionic-security main restricted
What are the broken packages?
Poperton
  • 1,283
software-properties-gtk
Change download source to main server. sudo apt update && sudo apt-get clean and try again.
Forgot, and unlock for other sources deb-src
nobody
  • 5,792
