Error message:
Please install all available updates for your release before upgrading.
Screenshot:
Refusal to update
Contents of /etc/update-manager/release-upgrades:
# Default behavior for the release upgrader.
[DEFAULT]
# Default prompting behavior, valid options:
#  never  - Never check for, or allow upgrading to, a new release.
#  normal - Check to see if a new release is available.  If more than one new
#           release is found, the release upgrader will attempt to upgrade to
#           the supported release that immediately succeeds the
#           currently-running release.
#  lts    - Check to see if a new LTS release is available.  The upgrader
#           will attempt to upgrade to the first LTS release available after
#           the currently-running one.  Note that if this option is used and
#           the currently-running release is not itself an LTS release the
#           upgrader will assume prompt was meant to be normal.
Prompt=normal
I've tried the obvious (apt update, apt upgrade, apt full-upgrade etc).
Adam Williams
  • 270
The problem was that the following packages were due to be updated:
➜  ~ sudo apt list --upgradable
Listing... Done
opendistro-alerting/stable 1.0.0.0-1 amd64 [upgradable from: 0.9.0.0-1]
opendistro-performance-analyzer/stable 1.0.0.0-1 amd64 [upgradable from: 0.9.0.0-1]
opendistro-security/stable 1.0.0.1-1 amd64 [upgradable from: 0.9.0.0-0]
opendistro-sql/stable 1.0.0.0-1 amd64 [upgradable from: 0.9.0.0-1]
opendistroforelasticsearch/stable 1.0.1-1 amd64 [upgradable from: 0.9.0-1]
Unfortunately, this could not happen in practice:
➜  ~ sudo apt install opendistro-alerting/stable
Reading package lists... Done
Building dependency tree
Selected version '1.0.0.0-1' (. stable:stable [amd64]) for 'opendistro-alerting'
The following packages have unmet dependencies.
 opendistro-alerting : Depends: elasticsearch-oss (= 7.0.1) but 6.7.1 is to be installed
I temporarily removed elasticsearch-oss and the opendistro- packages, and then do-release-upgrade worked as expected.
Adam Williams
  • 270
ubuntu 18.04 to ubuntu 19.04 is not a suported upgrade path
...that being said you can follow this guide:
https://www.linuxbabe.com/ubuntu/upgrade-ubuntu-18-04-to-ubuntu-19-04-directly-from-command-line
extract from the guide :
sudo apt update && sudo apt dist-upgrade
sudo apt install update-manager-core
sudo sed -i "s/Prompt=.*/Prompt=normal/g" /etc/update-manager/release-upgrades
sudo sed -i 's/bionic/disco/g' /etc/apt/sources.list
sudo sed -i 's/^/#/' /etc/apt/sources.list.d/*.list
sudo apt update
sudo apt upgrade
sudo apt autoremove
sudo apt clean
tatsu
  • 3,346
