Which is the best video editor for making YouTube videos in 18.04?
Something like adding in the video - texts and symbols ( or emojis ), and things around that line. Also, some method to export output in a format compatible with YouTube standards.
pomsky
  • 70,557
user227495
  • 4,309
Personally I'd recommend DaVinci Resolve.
Although I've used Kdenlive a ton, DaVinci is really high brow and yet free.
you can download it here:
http://www.danieltufvesson.com/makeresolvedeb
after that you can run it. I suggest watching one or two videos on it's different workflow.
they kinda reinvented the workflow and you don't have to use "their" workflow, but I honestly gotta say it's better than the workflow you'll typically have under apps like kdenlive or Premiere and saves alot of time so it's worth learning.
tatsu
  • 3,346
Apparently Cinelerra GG / Flowblade / Natron / Shotcut / Lightworks are a much better solution then DaVinci Resolve and compatible with Ubuntu to boot (which isn't really the case for Davinci Resolve).
These applications can be used together for a workflow, for example :
[Flowblade] -> [Natron]
Or all alone, for example :
[Cinelerra GG]
I haven't tried them but this is a much more appropriate answer given we're on ask ubuntu.
tatsu
  • 3,346
The following are good options:
  1. Kdenlive : This is usually the most preferred video editing tool for linux with a bunch of features and a lot of customization options. See the wiki page for more info.
  2. Openshot: I have personally used this and it also does a good job. However I had some issues with it as it used to hang sometimes. But overall it has quite user-friendly interface and is very easy to learn.
being_hd
  • 255
