I can boot into ubuntu only after I enter the "advanced options for ubuntu" and go into recovery mode where i need to select use the "repair broken packeges" option. The problem is that I want to boot on windows 10 but it doesn't apper as an option on grub. I have tried using terminal commands but when I reboot the computer it just crashes in a purple screen and I can't do anything else than shutting down my laptop. After shutting it down, the grub us not updated and I have to do the steps all over again. I would very much appreciate if someone could help me. Thanks!
And btw I don't mind having to uninstall ubuntu in order to get back the option of windows 10, or having to uninstall grub.
Since you need Recovery Mode, lets first check your file system for errors.
For 17.10 or older...
  • boot to the GRUB menu
  • choose Advanced Options
  • choose Recovery mode
  • choose Root access
  • at the # prompt, type sudo fsck -f /
  • repeat the fsck command if there were errors
  • type reboot
For 18.04 or newer...
  • boot to a Ubuntu Live DVD/USB
  • open a terminal window
  • type sudo fdisk -l
  • identify the /dev/XXXX device name for your "Linux Filesystem"
  • type sudo fsck -f /dev/XXXX # replacing XXXX with the number you found earlier
  • type reboot
After repairing any errors using fsck, if that doesn't solve the problem, try boot-repair. See...
https://help.ubuntu.com/community/Boot-Repair
heynnema
  • 73,649
