So apparently this is a common problem, however I have been googling this issue for a week and can't seem to fix it. powertop reports ~30W of power when nothing is running, which is too high. I did sudo prime-select intel but that doesn't lower power usage. I rebooted, but system froze before login and I had to prime-select nvidia from recovery to get it working again. I also echoed OFF to bbswitch (even though I don't have bumblebee installed), but it resets to on:
$ sudo bash -c "echo OFF > /proc/acpi/bbswitch"
$ echo /proc/acpi/bbswitch
0000:01:00.0 ON
Here is more information:
uname -a
Linux HOSTNAME 4.15.0-29-generic #31~16.04.1-Ubuntu SMP Wed Jul 18 08:54:04 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
$ sudo prime-select nvidia
Info: the current GL alternatives in use are: ['nvidia-410-prime', 'nvidia-410-prime']
Info: the current EGL alternatives in use are: ['nvidia-410-prime', 'nvidia-410-prime']
Info: selecting nvidia-410 for the nvidia profile
update-alternatives: using /usr/lib/nvidia-410/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) in manual mode
update-alternatives: using /usr/lib/nvidia-410/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_EGL.conf (x86_64-linux-gnu_egl_conf) in manual mode
update-alternatives: using /usr/lib/nvidia-410/alt_ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) in manual mode
update-alternatives: using /usr/lib/nvidia-410/alt_ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf (i386-linux-gnu_egl_conf) in manual mode
$ sudo prime-select intel
Info: the current GL alternatives in use are: ['nvidia-410', 'nvidia-410']
Info: the current EGL alternatives in use are: ['nvidia-410', 'nvidia-410']
Info: selecting nvidia-410-prime for the intel profile
update-alternatives: using /usr/lib/nvidia-410-prime/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) in manual mode
update-alternatives: using /usr/lib/nvidia-410-prime/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_EGL.conf (x86_64-linux-gnu_egl_conf) in manual mode
update-alternatives: using /usr/lib/nvidia-410-prime/alt_ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) in manual mode
update-alternatives: using /usr/lib/nvidia-410-prime/alt_ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf (i386-linux-gnu_egl_conf) in manual mode
$ ls /usr/lib/nvidia*
/usr/lib/nvidia:
pre-install
/usr/lib/nvidia-410:
alt_ld.so.conf libGLESv2_nvidia.so.2 libnvcuvid.so.1 libnvidia-fatbinaryloader.so.410.78 libnvidia-rtcore.so.410.78
bin libGLESv2_nvidia.so.410.78 libnvcuvid.so.410.78 libnvidia-fbc.so libnvidia-tls.so.410.78
ld.so.conf libGLESv2.so libnvidia-cbl.so.410.78 libnvidia-fbc.so.1 libnvidia-wfb.so.1
libEGL_nvidia.so.0 libGLESv2.so.2 libnvidia-cfg.so libnvidia-fbc.so.410.78 libnvidia-wfb.so.410.78
libEGL_nvidia.so.410.78 libGLESv2.so.2.1.0 libnvidia-cfg.so.1 libnvidia-glcore.so.410.78 libnvoptix.so.1
libEGL.so libGL.so libnvidia-cfg.so.410.78 libnvidia-glsi.so.410.78 libnvoptix.so.410.78
libEGL.so.1 libGL.so.1 libnvidia-compiler.so libnvidia-glvkspirv.so.410.78 libOpenGL.so
libEGL.so.1.1.0 libGL.so.1.7.0 libnvidia-compiler.so.1 libnvidia-ifr.so libOpenGL.so.0
libEGL.so.410.78 libGL.so.410.78 libnvidia-compiler.so.410.78 libnvidia-ifr.so.1 tls
libGLdispatch.so.0 libGLX_indirect.so.0 libnvidia-eglcore.so.410.78 libnvidia-ifr.so.410.78 vdpau
libGLESv1_CM_nvidia.so.1 libGLX_nvidia.so.0 libnvidia-egl-wayland.so.1 libnvidia-ml.so xorg
libGLESv1_CM_nvidia.so.410.78 libGLX_nvidia.so.410.78 libnvidia-egl-wayland.so.1.1.0 libnvidia-ml.so.1
libGLESv1_CM.so libGLX.so libnvidia-encode.so libnvidia-ml.so.410.78
libGLESv1_CM.so.1 libGLX.so.0 libnvidia-encode.so.1 libnvidia-ptxjitcompiler.so.1
libGLESv1_CM.so.1.2.0 libnvcuvid.so libnvidia-encode.so.410.78 libnvidia-ptxjitcompiler.so.410.78
/usr/lib/nvidia-410-prime:
alt_ld.so.conf ld.so.conf
$ lspci -k | grep -EA2 'VGA|3D'
00:02.0 VGA compatible controller: Intel Corporation Device 591b (rev 04)
DeviceName: Onboard IGD
Subsystem: Dell Device 07e1
01:00.0 3D controller: NVIDIA Corporation Device 1c8d (rev a1)
Kernel driver in use: nvidia
I am using a Dell Inspiron Laptop with i7 7700HQ and GTX 1050 mobility card. I have also tried the nvidia-430 driver (like maybe newer drivers have less issues), but with that X doesn't even start. So I reverted back to nvidia-410.
I also read some other links such as this and this one that had a modified prime-select script, but none of those have helped me so far.
I have also noticed that glxinfo doesn't work after switching to intel drivers (before reboot). It fails with the following output
name of display: :0
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
Error: couldn't find RGB GLX visual or fbconfig
132 GLX Visuals
<Long GLX Listings>
215 GLXFBConfigs:
<Longer GLXFB Listings>
I but that is probably not related to prime. It might be that nvidia-410 doesn't work at all with prime, and I need some other driver version for the GTX 1050m. I have been at this for weeks, missing my laptop's intel graphics and battery life on my linux. Any help would be greatly appreciated.
