I tried to use this method to upgrade the DTC version.
$ sudo apt install ./device-tree-compiler_1.4.7-1_amd64.deb
The result is disappointing:
Reading package lists... Done Building dependency tree
Note, selecting 'device-tree-compiler' instead of './device-tree-compiler_1.4.7-1_amd64.deb'
device-tree-compiler is already the newest version (1.4.7-1).
0 upgraded, 0 newly installed, 0 to remove and 14 not upgraded.
$ dtc -v
Version: DTC 1.4.0-gf345d9e4
I tried waltinator's suggestion,
$ sudo dpkg --install ./device-tree-compiler_1.4.7-1_amd64.deb
(Reading database ... 178854 files and directories currently installed.)
Preparing to unpack .../device-tree-compiler_1.4.7-1_amd64.deb ...
Unpacking device-tree-compiler (1.4.7-1) over (1.4.7-1) ...
Setting up device-tree-compiler (1.4.7-1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
But the version of dtc still not upgraded.
$ dtc -v
However, when I use this method to view the dtc version, the result is:
dpkg -s device-tree-compiler | grep '^Version:'
Version: 1.4.7-1
Why is this happening? What could be the issue?
Kulfy
  • 18,154
suroot
apt is an interface to the packaging system, and wants package names to install.
The tool to install a .deb file is dpkg. Read man dpkg and do something like:
waltinator
  • 37,856
You got this message because you manually downloaded device-tree-compiler_1.4.7-1_amd64.deb and locally installed this .deb file. If you install Synaptic package manager with sudo apt install synaptic and check it in Installed (local or obsolete) in the left pane it will show that device-tree-compiler is a locally installed package.
device-tree-compiler is in the default repositories of all currently supported versions of Ubuntu. The version of device-tree-compiler in Ubuntu 18.04 is 1.4.5. In Ubuntu 18.10 and later device-tree-compiler 1.4.7 can be installed from the terminal with the following command:
sudo apt install device-tree-compiler
karel
  • 122,292
  • 133
  • 301
  • 332
