Problem: MFU works like printer but didn't work like scanner.
Installed latest HPLIP Version: 3.19.6 from developers.hp.com.
:~$ hp-setup
hp-doctor command output:
| DISCOVERED SCANNER DEVICES |
No Scanner found.
| DISCOVERED USB DEVICES |
No devices found.
| INSTALLED CUPS PRINTER QUEUES |
HP-LaserJet-Pro-MFP-M125ra
Type: Unknown
Device URI: usb://HP/LaserJet%20Pro%20MFP%20M125ra?serial=CNB7GCJHZQ&interface=1
PPD: /etc/cups/ppd/HP-LaserJet-Pro-MFP-M125ra.ppd
warning: Failed to read /etc/cups/ppd/HP-LaserJet-Pro-MFP-M125ra.ppd ppd file
PPD Description:
Printer status: printer HP-LaserJet-Pro-MFP-M125ra is idle. enabled since Чт 06 июн 2019 17:54:40
warning: Printer is not HPLIP installed. Printers must use the hp: or hpfax: CUPS backend for HP-Devices.
| PERMISSION |
error: Unsupported model: HP_LaserJet_Pro_MFP_M125ra
Checking Permissions....
Checking for Configured Queues....
warning: Fail to read ppd=/etc/cups/ppd/HP-LaserJet-Pro-MFP-M125ra.ppd file
warning: Insufficient permission to access file /etc/cups/ppd/HP-LaserJet-Pro-MFP-M125ra.ppd
warning: Could not complete Queue(s) configuration check
Checking for HP Properitery Plugin's....
No plug-in printers are configured.
Diagnose completed...
lsusb command output:
Bus 002 Device 009: ID 03f0:222a Hewlett-Packard
sane-find-scanner command output:
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x03f0 [Hewlett-Packard], product=0x222a [HP LaserJet Pro MFP M125ra]) at libusb:002:009
could not open USB device 0x04d9/0x0175 at 002:006: Access denied (insufficient permissions)
could not open USB device 0x2109/0x2812 at 002:004: Access denied (insufficient permissions)
could not open USB device 0x0001/0x0000 at 002:003: Access denied (insufficient permissions)
could not open USB device 0x8087/0x0024 at 002:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0003 at 004:001: Access denied (insufficient permissions)
could not open USB device 0x046d/0xc52b at 003:003: Access denied (insufficient permissions)
could not open USB device 0x0461/0x0010 at 003:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 003:001: Access denied (insufficient permissions)
could not open USB device 0x8087/0x0024 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
# Your USB scanner was (probably) detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
# You may want to run this program as root to find all devices. Once you
# found the scanner devices, be sure to adjust access permissions as
# necessary.
Printer work without hplip setup.. How to make the scanner work?
