I was in the process of rsyncing data from /mnt/disk1 to /mnt/disk2 and had already modified fstab to remount /mnt/disk1 as /tmp. I didn't pay attention to the progress of the rsync and during the process some parts arrived for the system so I shut it down to install them. I know this is my own stupid fault, in 15 years I've never lost data like this so I'm venturing down a new trail.
Is there any way to recover the data in it's original structure and names? A total of 64K was written to the disk while mounted as /tmp. I'm running PhotoRec right now but the recovered data is not very usable (recup_dir.32/f03183747.txt as an example)
  1. Do not write to disk1 any more: use it for reading only.
  2. If you need to do writes, make a copy first using ddrescue and write to the copy only.
    apt install gddrescue
    man ddrescue
  3. If disk1 contains an ntfs file system, use RecuperaBit first!
    As ntfs contains multiple MFTs, you might recover some or all of the directory structure.
  4. If you arrive at this step, you probably have EXT2/3/4 FS on your disk. Recovering the directory structure is going to be difficult if both superblocks are overwritten: try this first on the copy you made from the original disk.
  5. Use TestDisk before you use PhotoRec
  6. Use autopsy before you use PhotoRec
  7. Use R-Disk before using PhotoRec
  8. Only if all else fails, start using PhotoRec
The best solution here is to restore your backup thought and if you don't have a backup, start making a backup ASAHP
Fabby
  • 35,017
