Using GNOME tweak tool, I have already selected off to 'Suspend when laptop lid is closed'. So, the system doesn't suspend. But, when I close the lid and reopen it, system goes in aeroplane mode and hence WiFi and bluetooth get disconnected.
Asked
Active
Viewed 1,755 times
I had the same problem. (Do you have a HP laptop?)
The next steps will test if you have the same problem as I had and also will provide solution. It is based in a very useful comment from usser "ebin92" on reddit about this topic.
TEST
We gonna check if the open/close lid event is sending scancodes and, if so, remap them
- Open a terminal and type:
<journalctl -f> - Then open and close the lid, and check in the terminal for an unknown scancode (in my case they were "e058" and "e057")
- Remap the scancodes that your lid are sending to DISPLAY OFF code (you can remap it to another keycode if you want)
For that, use >>
setkeycodes [SCANCODE] [KEYCODE]In my case, >>setkeycodes e058 245 e057 245
Try again opening and closing your lid and if the problem is solved, lets make it permanent.
PERMANENT FIX
We are going to enable a new systemd service to remap the scancodes on boot up
- Open a terminal and go to /etc/systemd/system. Execute next steps as superuser
- Create a new file with name format "YOURNAME.service". In my case it was "lidbehaviour_override.service"
- Put inside the attached content (see below) and edit the keycodes to your case
- Give to the file execution permissions, running >>
sudo chdmod a+x FILENAMEIn my case >>sudo chdmod a+x lidbehaviour_override.service - Test everything is fine running the service. For that:
· reload the daemon configuration (all you have modified in systemd) with
sudo systemctl daemon-reload· run the new service withsudo systemctl start YOURNAME.serviceIn my casesystemctl start lidbehaviour_override.service· Open and close the lid - If everything went right, then make the service starts on boot up
sudo systemctl enable YOURNAME.serviceIn my casesystemctl enable lidbehaviour_override.service
SYSTEMD SERVICE CONTENT
[Unit]
Description=Fix aeroplane mode on/off when lid opens/closes
[Service]
ExecStart=/usr/bin/setkeycodes e058 245 e057 245
[Install]
WantedBy=multi-user.target
