I re-partitioned my Windows 10 (1TB), installed along side Ubuntu and allocated(40GB).
Now I would like to increase the size of my Ubuntu from 40GB => 200GB ?
FYI: Already installed gparted. Confused on what to do now.
Screenshot
heynnema
  • 73,649
Deejay
  • 111
Make sure that you have a good backup of your important Windows and Ubuntu files, as this procedure can corrupt or loose data.
This is a two part process. Resize the Windows NTFS partition, and move/resize the Ubuntu partition.
In Windows...
  • temporarily disable the pagefile using the System control panel
  • reboot
  • defrag
  • use the Disk Management app to resize the Windows NTFS C: partition
  • open a CMD (command) terminal with admin privs
  • issue a chkdsk /f C: and confirm to do this on next reboot
  • reboot, observe chkdsk running
  • reboot and confirm that Windows still boots
  • re-enable the pagefile
For Ubuntu...
Keep these things in mind:
  • always start the entire procedure with issuing a swapoff on any mounted swap partitions, and end the entire procedure with issuing a swapon on that same swap partition
  • a move is done by pointing the mouse pointer at the center of a partition and dragging it left/right with the hand cursor
  • a resize is done by dragging the left/right side of a partition to the left/right with the directional arrow cursor
  • if any partition can't be moved/resized graphically, you may have to manually enter the specific required numeric data (don't do this unless I instruct you to)
  • you begin any move/resize by right-clicking on the partition in the lower pane of the main window, and selecting the desired action from the popup menu, then finishing that action in the new move/resize window
Do the following...
Note: if the procedure doesn't work exactly as I outline, STOP immediately and DO NOT continue.
  • boot to a Ubuntu Live DVD/USB
  • start gparted
  • move /dev/sda6 partition all the way left
  • resize the right side of /dev/sda6 all the way right
  • click the Apply icon
  • reboot
heynnema
  • 73,649
