I would like to remove emacs25 entirely from my system and keep emacs26. Unfortunately, I am stuck in a fix-broken state
Here is the output...
Try to remove emacs25
> $ sudo apt remove emacs25        [±530-skurnik-depletions ✓]
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 emacs : Depends: emacs25 or
                  emacs25-lucid but it is not going to be installed or
                  emacs25-nox but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
ok so let's try and fix the broken install...
> $ sudo apt --fix-broken install        [±530-skurnik-depletions ✓]
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
  xaw3dg
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
  emacs25-common
The following NEW packages will be installed:
  emacs25-common
0 upgraded, 1 newly installed, 0 to remove and 239 not upgraded.
13 not fully installed or removed.
Need to get 0 B/17.5 MB of archives.
After this operation, 70.3 MB of additional disk space will be used.
Do you want to continue? [Y/n]
(Reading database ... 261624 files and directories currently installed.)
Preparing to unpack .../emacs25-common_25.3~1.gite0284ab-kk1+18.04_all.deb ...
Unpacking emacs25-common (25.3~1.gite0284ab-kk1+18.04) ...
dpkg: error processing archive /var/cache/apt/archives/emacs25-common_25.3~1.gite0284ab-kk1+18.04_all.deb (--unpack):
 trying to overwrite '/usr/share/emacs/site-lisp/subdirs.el', which is also in package emacs26-common 26.1~1.git07f8f9b-kk1+18.04
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
How about trying to force it? Same result.
> $ sudo apt-get -f install        [±530-skurnik-depletions ✓]
  xaw3dg
  emacs25-common
  emacs25-common
ok, let's purge!
> $ sudo apt-get purge emacs25        [±530-skurnik-depletions ✓]
I solved this by removing all of the packages that depend on emacs using dpkg -r.
> $ sudo dpkg -r emacs
dpkg: dependency problems prevent removal of emacs:
 elpa-flx depends on emacs.
 elpa-flx-ido depends on emacs; however:
  Package emacs is to be removed.
 elpa-epl depends on emacs.
dpkg: error processing package emacs (--remove):
 dependency problems - not removing
 emacs
So, uninstall elpa-flx...
> $ sudo dpkg -r elpa-flx
dpkg: dependency problems prevent removal of elpa-flx:
 elpa-flx-ido depends on elpa-flx (= 0.6.1-1).
dpkg: error processing package elpa-flx (--remove):
 elpa-flx
> $ sudo dpkg -r elpa-flx-ido
(Reading database ... 261601 files and directories currently installed.)
Removing elpa-flx-ido (0.6.1-1) ...
(Reading database ... 261593 files and directories currently installed.)
Removing elpa-flx (0.6.1-1) ...
 emacs
> $ sudo dpkg -r elpa-epl
(Reading database ... 261582 files and directories currently installed.)
Removing elpa-epl (0.9-1) ...
(Reading database ... 261571 files and directories currently installed.)
Removing emacs (47.0) ...
