I was trying to install Ubuntu 16.04 on my laptop(Asus) but NOT with windows as I erased the full drive to be just for linux. I had the problem of GRUB which is:
Unable to install GRUB in /dev/sda
Executing grub-install /dev/sda failed.
This is a fatal error.
I tried to use boot-repair but it didn't work. so next I tried to remove all the partitions and create new ones and in the boot loader installation I added the exact location where the Ubuntu should be installed eg:/sdb1
problem now is that it finish the installation, tells me to restart the device but when I do, it boots from the USB and its like no operating system is there from the first place to boot from.
I checked my BIOS and if I remove the bootable USB it says NO BOOTABLE DEVICES and when I do put it back it can only see the USB.
If anyone knows please try to elaborate your solution in the best way as I am a bit new to these fixes
Thank you
