I am using this guide to check available disk space. For that, I tried using the last option to see space in one full number. But I am unable to see it.
This is the error I got:
$ sudo apt-get install btrfs-tools
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
btrfs-tools : Depends: btrfs-progs but it is not going to be installed
libfreetype6 : Breaks: libfreetype6:i386 (!= 2.8-0.2)
but 2.8.1-2ubuntu2 is to be installed  libfreetype6:i386 : Breaks:
libfreetype6 (!= 2.8.1-2ubuntu2) but 2.8-0.2 is to be installed
libfreetype6-dev : Depends: libfreetype6 (= 2.8.1-2ubuntu2) but 2.8-0.2 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I am not sure what this error means.
Any help will be much appreciated.
Please see log
root@asdsd:/home# sudo apt-get install btrfs-tools
 libfreetype6 : Breaks: libfreetype6:i386 (!= 2.8-0.2) but 2.8.1-2ubuntu2 is to be installed
 libfreetype6:i386 : Breaks: libfreetype6 (!= 2.8.1-2ubuntu2) but 2.8-0.2 is to be installed
root@asdsd:/home# sudo apt --fix-broken install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  bamfdaemon blt command-not-found-data gir1.2-accounts-1.0 gir1.2-appindicator3-0.1 gir1.2-clutter-1.0 gir1.2-cogl-1.0 gir1.2-coglpango-1.0
  gir1.2-gdata-0.0 gir1.2-rb-3.0 gir1.2-signon-1.0 gir1.2-totem-1.0 gir1.2-totemplparser-1.0 gtk3-nocsd hud intel-gpu-tools libatkmm-1.6-1v5
  libaudio2:i386 libcairomm-1.0-1v5 libcolumbus1-common libcolumbus1v5 libdbusmenu-qt2:i386 libdbusmenu-qt5-2 libdmapsharing-3.0-2 libframe6
  libgeis1 libgeonames-common libgeonames0 libglewmx1.13 libgpod-common libgpod4 libgrail6 libgsettings-qt1 libgtk3-nocsd0 libgtkmm-3.0-1v5
  libice6:i386 liblirc-client0 libmetacity1 libmng2:i386 libmodplug1 libmpdec2:i386 libnih-dbus1 libnm-gtk0 libnux-4.0-0 libnux-4.0-common
  libpangomm-1.4-1v5 libpng12-0:i386 libpython-all-dev libpython3-stdlib:i386 libpython3.6-minimal:i386 libpython3.6-stdlib:i386
  libpython3.7-minimal libpython3.7-stdlib libqt4-dbus:i386 libqt4-declarative:i386 libqt4-network:i386 libqt4-opengl:i386 libqt4-script:i386
  libqt4-sql:i386 libqt4-sql-mysql:i386 libqt4-xml:i386 libqt4-xmlpatterns:i386 libqtcore4:i386 libqtdbus4:i386 libqtgui4:i386
  libqtwebkit4:i386 libreadline7:i386 libsgutils2-2 libsignon-glib1 libsm6:i386 libssl1.0.0:i386 libssl1.1:i386 libtbb2 libtimezonemap-data
  libtimezonemap1 libunity-core-6.0-9 libunity-misc4 libxss1:i386 libxt6:i386 libxv1:i386 libzeitgeist-1.0-1 libzip5 metacity-common
  mongo-tools nux-tools php-http-request php-net-socket php-net-url php-net-url2 python-all python-asn1crypto python-cffi-backend
  python-crypto python-cryptography python-dbus python-enum34 python-idna python-ipaddress python-keyring python-keyrings.alt
  python-secretstorage python-wheel python-xdg python3-blinker python3-bs4 python3-feedparser python3-html5lib python3-jwt
  python3-webencodings qt-at-spi:i386 session-shortcuts sni-qt:i386 tk8.6-blt2.5 unity-asset-pool unity-lens-applications unity-lens-files
  unity-lens-music unity-lens-video unity-schemas unity-scope-home unity-scope-video-remote unity-scopes-master-default unity-scopes-runner
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  libfreetype6
The following packages will be upgraded:
  libfreetype6
1 upgraded, 0 newly installed, 0 to remove and 268 not upgraded.
2 not fully installed or removed.
Need to get 0 B/335 kB of archives.
After this operation, 6,144 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 246177 files and directories currently installed.)
Preparing to unpack .../libfreetype6_2.8.1-2ubuntu2_amd64.deb ...
Unpacking libfreetype6:amd64 (2.8.1-2ubuntu2) over (2.8-0.2) ...
dpkg: error processing archive /var/cache/apt/archives/libfreetype6_2.8.1-2ubuntu2_amd64.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libfreetype6/changelog.Debian.gz', which is different from other instances of package libfreetype6:amd64
root@asdsd:/home# sudo apt autoclean;
Del php7.1-curl 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [28.8 kB]
Del libglib2.0-dev 2.56.4-0ubuntu0.18.04.2 [1,384 kB]
Del php7.2-opcache 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [165 kB]
Del cups-ppdc 2.2.7-1ubuntu2.5 [26.8 kB]
Del php7.2-tidy 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [16.9 kB]
Del php7.3-readline 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [12.0 kB]
Del php7.2-odbc 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [30.4 kB]
Del mutter 3.28.3+git20190124-0ubuntu18.04.2 [15.5 kB]
Del libsystemd0 237-3ubuntu10.21 [221 kB]
Del cups-server-common 2.2.7-1ubuntu2.5 [415 kB]
Del g++ 4:7.4.0-1ubuntu2.2 [1,568 B]
Del binutils-x86-64-linux-gnu 2.30-21ubuntu1~18.04.1 [1,854 kB]
Del php7.1-intl 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [129 kB]
Del gcc-7-base 7.4.0-1ubuntu1~18.04 [19.0 kB]
Del php7.2-snmp 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [18.5 kB]
Del php7.1-cli 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [1,344 kB]
Del php7.2-mbstring 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [485 kB]
Del libbinutils 2.30-21ubuntu1~18.04.1 [501 kB]
Del libcups2 2.2.7-1ubuntu2.5 [225 kB]
Del php5.6-json 5.6.40-7+ubuntu18.04.1+deb.sury.org+1 [17.9 kB]
Del cups 2.2.7-1ubuntu2.5 [191 kB]
Del php7.2-fpm 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [1,412 kB]
Del php7.2-cgi 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [1,368 kB]
Del php5.6-curl 5.6.40-7+ubuntu18.04.1+deb.sury.org+1 [28.3 kB]
Del php7.2-bcmath 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [15.4 kB]
Del libudev1 237-3ubuntu10.21 [57.3 kB]
Del libapache2-mod-php7.2 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [1,350 kB]
Del php7.1-json 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [17.5 kB]
Del php7.3-zip 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [20.4 kB]
Del libgfortran4 7.4.0-1ubuntu1~18.04 [492 kB]
Del php7.1-mbstring 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [469 kB]
Del php7.3-mysql 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [116 kB]
Del gcc-8-base 8.3.0-6ubuntu1~18.04 [18.6 kB]
Del php7.2-gmp 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [20.2 kB]
Del php7.3-bz2 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [10.2 kB]
Del php7.2-gd 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [27.2 kB]
Del php7.1-mysql 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [120 kB]
Del libudev1 237-3ubuntu10.21 [54.0 kB]
Del libgomp1 8.3.0-6ubuntu1~18.04 [76.4 kB]
Del php7.2-json 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [18.8 kB]
Del php7.2-phpdbg 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [1,448 kB]
Del libmutter-2-0 3.28.3+git20190124-0ubuntu18.04.2 [1,208 kB]
Del mutter-common 3.28.3+git20190124-0ubuntu18.04.2 [13.3 kB]
Del php7.1-zip 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [20.2 kB]
Del systemd-sysv 237-3ubuntu10.21 [11.6 kB]
Del libglib2.0-0 2.56.4-0ubuntu0.18.04.2 [1,237 kB]
Del libcupsimage2 2.2.7-1ubuntu2.5 [18.6 kB]
Del php7.1-gmp 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [21.3 kB]
Del php5.6-readline 5.6.40-7+ubuntu18.04.1+deb.sury.org+1 [12.9 kB]
Del php7.3-xml 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [106 kB]
Del libgcc1 1:8.3.0-6ubuntu1~18.04 [40.7 kB]
Del php7.2-soap 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [113 kB]
Del cups-common 2.2.7-1ubuntu2.5 [206 kB]
Del php7.2-pgsql 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [56.0 kB]
Del libapache2-mod-php7.1 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [1,284 kB]
Del php7.2-mysql 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [117 kB]
Del php7.2-dev 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [555 kB]
Del libsystemd0 237-3ubuntu10.21 [204 kB]
Del php7.1-xml 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [115 kB]
Del php7.1-common 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [903 kB]
Del libstdc++6 8.3.0-6ubuntu1~18.04 [400 kB]
Del php7.3-mbstring 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [511 kB]
Del php5.6-common 5.6.40-7+ubuntu18.04.1+deb.sury.org+1 [2,764 kB]
Del libglib2.0-dev-bin 2.56.4-0ubuntu0.18.04.2 [102 kB]
Del libasan4 7.4.0-1ubuntu1~18.04 [359 kB]
Del php7.2-pspell 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [8,504 B]
Del libquadmath0 8.3.0-6ubuntu1~18.04 [134 kB]
Del libtsan0 8.3.0-6ubuntu1~18.04 [288 kB]
Del libglib2.0-data 2.56.4-0ubuntu0.18.04.2 [4,720 B]
Del liblsan0 8.3.0-6ubuntu1~18.04 [133 kB]
Del g++-7 7.4.0-1ubuntu1~18.04 [7,575 kB]
Del libpam-systemd 237-3ubuntu10.21 [108 kB]
Del software-properties-gtk 0.96.24.32.8 [62.3 kB]
Del php7.3-cli 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [1,376 kB]
Del php7.2-ldap 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [23.7 kB]
Del php7.3-curl 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [29.6 kB]
Del libstdc++6 8.3.0-6ubuntu1~18.04 [432 kB]
Del gir1.2-mutter-2 3.28.3+git20190124-0ubuntu18.04.2 [139 kB]
Del php7.2-dba 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [23.2 kB]
Del cpp-7 7.4.0-1ubuntu1~18.04 [6,740 kB]
Del gcc-7 7.4.0-1ubuntu1~18.04 [7,462 kB]
Del php7.3-common 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [939 kB]
Del php7.2-recode 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [5,644 B]
Del php7.2-curl 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [28.8 kB]
Del php7.2-zip 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [20.6 kB]
Del php7.1-readline 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [12.5 kB]
Del gcc 4:7.4.0-1ubuntu2.2 [5,184 B]
Del php7.3-json 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [18.4 kB]
Del software-properties-common 0.96.24.32.8 [9,992 B]
Del cups-client 2.2.7-1ubuntu2.5 [139 kB]
Del php7.2-intl 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [125 kB]
Del libnss-systemd 237-3ubuntu10.21 [105 kB]
Del libcupsppdc1 2.2.7-1ubuntu2.5 [45.0 kB]
Del binutils-common 2.30-21ubuntu1~18.04.1 [193 kB]
Del systemd 237-3ubuntu10.21 [2,901 kB]
Del php7.1-gd 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [27.9 kB]
Del cups-core-drivers 2.2.7-1ubuntu2.5 [27.8 kB]
Del php7.3 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [35.8 kB]
Del libnss-myhostname 237-3ubuntu10.21 [34.0 kB]
Del php7.2-sybase 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [11.3 kB]
Del php7.0-common 7.0.33-7+ubuntu18.04.1+deb.sury.org+1 [896 kB]
Del libcupsmime1 2.2.7-1ubuntu2.5 [13.2 kB]
Del udev 237-3ubuntu10.21 [1,102 kB]
Del php7.0-curl 7.0.33-7+ubuntu18.04.1+deb.sury.org+1 [27.9 kB]
Del libglib2.0-bin 2.56.4-0ubuntu0.18.04.2 [68.9 kB]
Del libapache2-mod-php5.6 5.6.40-7+ubuntu18.04.1+deb.sury.org+1 [1,256 kB]
Del php7.2 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [49.0 kB]
Del libcups2 2.2.7-1ubuntu2.5 [211 kB]
Del libapache2-mod-php7.3 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [1,322 kB]
Del php7.2-imap 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [29.1 kB]
Del libglib2.0-0 2.56.4-0ubuntu0.18.04.2 [1,169 kB]
Del libitm1 8.3.0-6ubuntu1~18.04 [27.9 kB]
Del php7.2-sqlite3 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [25.4 kB]
Del cups-ipp-utils 2.2.7-1ubuntu2.5 [210 kB]
Del libubsan0 7.4.0-1ubuntu1~18.04 [126 kB]
Del php7.2-bz2 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [10.3 kB]
Del cups-bsd 2.2.7-1ubuntu2.5 [38.4 kB]
Del python3-software-properties 0.96.24.32.8 [23.7 kB]
Del libcc1-0 8.3.0-6ubuntu1~18.04 [47.4 kB]
Del cups-daemon 2.2.7-1ubuntu2.5 [296 kB]
Del php7.2-common 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [926 kB]
Del libatomic1 8.3.0-6ubuntu1~18.04 [9,180 B]
Del php7.2-xmlrpc 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [12.8 kB]
Del libcilkrts5 7.4.0-1ubuntu1~18.04 [42.5 kB]
Del php7.2-cli 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [1,407 kB]
Del php5.6 5.6.40-7+ubuntu18.04.1+deb.sury.org+1 [263 kB]
Del php7.1-bcmath 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [15.9 kB]
Del php7.0-gmp 7.0.33-7+ubuntu18.04.1+deb.sury.org+1 [21.6 kB]
Del libstdc++-7-dev 7.4.0-1ubuntu1~18.04 [1,467 kB]
Del php7.3-opcache 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [181 kB]
Del libgcc1 1:8.3.0-6ubuntu1~18.04 [48.2 kB]
Del php7.2-xml 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [107 kB]
Del php7.3-odbc 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [30.5 kB]
Del php5.6-cli 5.6.40-7+ubuntu18.04.1+deb.sury.org+1 [1,301 kB]
Del cpp 4:7.4.0-1ubuntu2.2 [27.6 kB]
Del php7.3-intl 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [124 kB]
Del libgcc-7-dev 7.4.0-1ubuntu1~18.04 [2,381 kB]
Del php5.6-opcache 5.6.40-7+ubuntu18.04.1+deb.sury.org+1 [62.6 kB]
Del gcc-8-base 8.3.0-6ubuntu1~18.04 [18.7 kB]
Del libmpx2 8.3.0-6ubuntu1~18.04 [11.6 kB]
Del php7.2-interbase 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [40.2 kB]
Del libcupscgi1 2.2.7-1ubuntu2.5 [27.4 kB]
Del php7.3-gd 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [26.9 kB]
Del php7.2-xsl 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [48.7 kB]
Del binutils 2.30-21ubuntu1~18.04.1 [3,396 B]
Del php7.1 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [62.0 kB]
Del php7.0-mcrypt 7.0.33-7+ubuntu18.04.1+deb.sury.org+1 [14.9 kB]
Del php7.1-opcache 7.1.29-1+ubuntu18.04.1+deb.sury.org+1 [147 kB]
Del php7.2-readline 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [12.2 kB]
Del php7.2-enchant 7.2.18-1+ubuntu18.04.1+deb.sury.org+1 [9,108 B]
Del php7.3-bcmath 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 [15.0 kB]
root@asdsd:/home# sudo apt autoremove;
 libfreetype6 : Breaks: libfreetype6:i386 (!= 2.8-0.2) but 2.8.1-2ubuntu2 is installed
 libfreetype6:i386 : Breaks: libfreetype6 (!= 2.8.1-2ubuntu2) but 2.8-0.2 is installed
 libfreetype6-dev : Depends: libfreetype6 (= 2.8.1-2ubuntu2) but 2.8-0.2 is installed
root@asdsd:/home# sudo apt update
Ign:1 http://binaries.erlang-solutions.com/debian bionic InRelease
Get:2 http://packages.microsoft.com/repos/vscode stable InRelease [3,182 B]
Ign:3 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/4.0 InRelease
Hit:4 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/4.0 Release
Hit:5 http://binaries.erlang-solutions.com/debian bionic Release
Get:6 http://archive.canonical.com bionic InRelease [10.2 kB]
Hit:7 http://archive.ubuntu.com/ubuntu bionic InRelease
Ign:8 http://us.archive.ubuntu.com/ubuntu artful-updates InRelease
Get:9 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Err:10 http://us.archive.ubuntu.com/ubuntu artful-updates Release
  404  Not Found [IP: 91.189.91.23 80]
Get:11 http://linux.teamviewer.com/deb stable InRelease [9,388 B]
Get:12 http://packages.microsoft.com/repos/vscode stable/main amd64 Packages [125 kB]
Hit:14 http://ppa.launchpad.net/apt-fast/stable/ubuntu bionic InRelease
Hit:15 https://download.sublimetext.com apt/stable/ InRelease
Hit:16 http://archive.ubuntu.com/ubuntu xenial InRelease
Hit:18 http://ppa.launchpad.net/ondrej/php/ubuntu bionic InRelease
Get:19 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Ign:20 https://dl.bintray.com/rabbitmq/debian xenial InRelease
Get:21 https://dl.bintray.com/rabbitmq/debian xenial Release [66.8 kB]
Hit:22 http://ppa.launchpad.net/webupd8team/atom/ubuntu bionic InRelease
Get:23 http://archive.canonical.com bionic/partner i386 Packages [2,316 B]
Get:24 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:25 http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease
Get:26 http://archive.canonical.com bionic/partner amd64 Packages [2,316 B]
Get:27 http://archive.ubuntu.com/ubuntu bionic-security/main i386 Packages [338 kB]
Get:28 http://archive.ubuntu.com/ubuntu bionic-security/main amd64 Packages [447 kB]
Get:29 http://archive.ubuntu.com/ubuntu bionic-security/main Translation-en [156 kB]
Get:31 http://archive.ubuntu.com/ubuntu bionic-security/main amd64 DEP-11 Metadata [24.1 kB]
Get:32 http://archive.ubuntu.com/ubuntu bionic-security/main DEP-11 48x48 Icons [10.4 kB]
Get:33 http://archive.ubuntu.com/ubuntu bionic-security/main DEP-11 64x64 Icons [31.7 kB]
Get:34 http://archive.ubuntu.com/ubuntu bionic-security/universe i386 Packages [563 kB]
Get:35 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [570 kB]
Get:36 http://archive.ubuntu.com/ubuntu bionic-security/universe Translation-en [185 kB]
Get:37 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 DEP-11 Metadata [41.2 kB]
Get:38 http://archive.ubuntu.com/ubuntu bionic-security/universe DEP-11 48x48 Icons [16.4 kB]
Get:39 http://archive.ubuntu.com/ubuntu bionic-security/universe DEP-11 64x64 Icons [111 kB]
Get:40 http://archive.ubuntu.com/ubuntu bionic-security/multiverse amd64 DEP-11 Metadata [2,464 B]
Get:41 http://archive.ubuntu.com/ubuntu bionic-backports/universe amd64 DEP-11 Metadata [7,224 B]
Get:42 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2,468 B]
Get:43 http://archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [949 kB]
Get:44 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [965 kB]
Get:45 http://archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [287 kB]
Get:46 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [249 kB]
Get:47 http://archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [203 kB]
Get:48 http://archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [423 kB]
Get:49 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [676 kB]
Get:50 http://archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages [555 kB]
Get:51 http://archive.ubuntu.com/ubuntu bionic-updates/main Translation-en [249 kB]
Get:52 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 DEP-11 Metadata [283 kB]
Get:53 http://archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 48x48 Icons [66.7 kB]
Get:54 http://archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 64x64 Icons [134 kB]
E: The repository 'http://us.archive.ubuntu.com/ubuntu artful-updates Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
root@asdsd:/home#
FedKad
  • 13,420
Rahul
  • 321
