$ cat /etc./issue
$ Ubuntu 18.04.1 LTS
I've installed python3.6 and python3.7 from sorces. Now i'm trying to install gnome-terminal (which was for some reason removed along with python3), I fire off the following command:
$ sudo apt-get install gnome-terminal
That line is executed and yields the following output:
Reading package lists... Done
Building dependency tree
gnome-terminal : Depends: python3 but it is not going to be installed
Depends: python3-gi but it is not going to be installed
It keeps mentioning python3 but it is installed, I can do:
$ python3 --version
$ Python 3.6.5
If I try:
$ sudo apt-get install python3
I get the following error:
python3 : PreDepends: python3-minimal (= 3.6.5-3) but it is not going to be installed
Depends: python3.6 (>= 3.6.5-2~) but it is not going to be installed
Depends: libpython3-stdlib (= 3.6.5-3) but 3.6.7-1~18.04 is to be installed
If I try:
$ sudo apt-get install python3-minimal
I get:
python3-minimal : Depends: python3.6-minimal (>= 3.6.5-2~) but it is not going to be installed
And so on...what should I do?! I've entirely run out of ideas...
