Background: I'm trying to build my program but first I need to set up libraries in NetBeans. My project is using GLU and therefore I installed libglu-dev. I didn't note the location where the libraries were located and now I can't find them.
I've switched to Linux just a few days ago and so far I'm very content with it, however I couldn't google this one out and became frustrated. Is there way to find out where files of package were installed without running the installation again? I mean if I got library xxx and installed it some time ago, is there some-command xxx that will print this info?
I've already tried locate, find and whereis commands, but either I'm missing something or I just can't do it correctly. For libglu, locate returns:
/usr/share/bug/libglu1-mesa
/usr/share/bug/libglu1-mesa/control
/usr/share/bug/libglu1-mesa/script
/usr/share/doc/libglu1-mesa
/usr/share/doc/libglu1-mesa/changelog.Debian.gz
/usr/share/doc/libglu1-mesa/copyright
/usr/share/lintian/overrides/libglu1-mesa
/var/lib/dpkg/info/libglu1-mesa:i386.list
/var/lib/dpkg/info/libglu1-mesa:i386.md5sums
/var/lib/dpkg/info/libglu1-mesa:i386.postinst
/var/lib/dpkg/info/libglu1-mesa:i386.postrm
/var/lib/dpkg/info/libglu1-mesa:i386.shlibs
The other two commands fail to find anything. Now locate did its job, but I'm sure none of those paths is where the library actually resides (at least everything I was linking so far was in /usr/lib or /usr/local/lib).
libglu was introduced just as example. I'm looking for a general solution for this problem.
