All the CSV to TSV tutorials are suggesting a simple:
tr ',' '\t'
though some CSVs look like this:
1,310,"IntAct,PINA"
in which case I would like to keep "IntAct,PINA":
1   310 "IntAct,PINA"
How could I parameterize the tr command (or sed, etc.) in order to do that?
I appreciate any suggestions.
Eliah Kagan
  • 119,640
Use csvformat from csvkit:
csvformat -d, -D$'\t' file
or shorter:
csvformat -T file
-d input delimiter (not needed here, as , is the default input delimiter)
-D output delimiter
-T set tabs as output delimiter
It will remove the quotes, as they are not needed for a tsv.
You should be able to install csvkit via pip:
sudo apt install python-pip
pip install csvkit
pLumo
  • 27,991
If csvkit (which I recommend) is not available, then you could use the perl Text::CSV module:
perl -MText::CSV -lne '
  BEGIN{$p = Text::CSV->new} print join "\t", $p->fields() if $p->parse($_)
' file
If you insist on retaining the quoting (which is unnecessary, since the embedded , is no longer a separator), then you could do something like
print join "\t", map { $_ =~ s/.*,.*/"$&"/r } $p->fields() if $p->parse($_)
steeldriver
  • 142,475
Using your CSV without heading
1,310,"IntAct,PINA"
and Miller (https://github.com/johnkerl/miller)
mlr --nidx --ifs "," --ofs "\t" cat input.csv
gives you back
1       310     "IntAct PINA"
aborruso
  • 814
