I'm running 16.04 on several cloud servers, stock hardware, no GUI, all LAMP. I want to upgrade from 16.04 to 18.04.
What can we do before or during an upgrade to give us a better chance of success? Getting a backup is obvious. Might we have a better chance of success if we do something to simplify the installation? Maybe do a pre-upgrade of some components? To ensure the process isn't interrupted if my SSH connection dies, I'll use an HTTP-based virtual console.
I just want to avoid a failed upgrade, downtime, inability to access the server to fix it, and other grief. I don't want to miss doing something that others might think is obvious, expected, or good practice.
Melebius
  • 11,750
TonyG
  • 187
From my experiences, I recommend cloning your production server(s) and test the upgrade on the clone first. I usually cloned my physical server to a virtual machine on my laptop in such a case, the process will be likely easier in the cloud.
I’ve never had any problems with the upgrade itself (like getting stuck in the middle, died SSH, etc.) but something might stop working after the upgrade if you depend on some default settings which change during the upgrade, use a non-Ubuntu software, etc. You can detect such problems by running the clone.
Upgrading through SSH is officially not recommended but it can be done. The installer provides a backup SSH server (on a different port) for the case something goes wrong. And since the installer runs the upgrade in a screen session, you can reconnect to it using an HTTP-based virtual console even when it was started using SSH.
I’d discourage you from this idea. The installer knows the right order to gradually upgrade packages. Don’t disrupt it by potentially introducing unnecessary conflicts.
Melebius
  • 11,750
